Hot Rods Model T rear spring in a 34
Discussion in 'The Hokey Ass Message Board' started by panhead_pete, Mar 25, 2023.
  1. panhead_pete
    panhead_pete
    Now I have the plan sorted for my front end, thanks all, its time to start planning out the rear.
    This winter will be ripping out the C2 vette rear for a couple reasons and going to a 9 inch and ladder bar set up. Failing that a 8.8 with ladder bars. Tossing up with going with coil overs (least prefered) or traverse spring. Either way will need a new crossmember.
    I have a rear T spring laying around I bought for my A coupe to lower it but that car now has a new caretaker. Just sitting here with a beverage thinking if I could use that and a tubular buggy spring cross member with the T spring with appropiate mounts on the 9 inch? Pic from Cory`s site.
    rod1 likes this.
  2. It should work as long as your happy with the ride height.A straight cross member will lift the car. In the early days it was common to use the Model A rear cross member with a A, or T spring in a 34. This was done to clear a quick change rear end. The curved cross member brought the back of the car down in the rear.The trunk floor would then need a hole cut for the cross member.
    dana barlow and rod1 like this.
  3. panhead_pete
    panhead_pete
    Cheers @irishsteve. Does make a lot of sense re using an A crossmember.
  4. 100% Matt
    100% Matt
    panhead_pete likes this.
  5. panhead_pete
    panhead_pete
