Technical Model T rear spring in a ModelA
Discussion in 'The Hokey Ass Message Board' started by Jethro, May 31, 2024.
  1. Jethro
    Jethro
    I was initially going to try and reverse the eyes on a model A rear spring. After doing the front spring I no longer had the strength or will to attempt it. I know Millworks makes a really nice rear spring but by the time it would get here the cost would be well above $1000.00 Canadian .
    I already had a Speedway reverse eye T spring and wondered how I could make it work. People talk about how the T spring has a different radius than an A spring. Also the T spring pack is a little shorter and needs a spacer to be able to clamp it properly.
    I marked out the A radius on the top of a piece of maple and the T radius underneath , then tried the fit. It looked like it was going to work! Truth be known , I think the maple block would have worked on it's own .....for a while anyway. I wanted a more permanent solution so I rammed the wood spacer into 20240531_125938.jpg 20240531_130027.jpg 20240531_130039.jpg some casting sand and poured some hot beer cans into the space left behind. The spacer turned out pretty good! I drilled it and turned a spud to locate it in the cross member and pressed it in place.
    It looks like it will work just fine once I get the rear end in place and the spring mounts fabbed and welded.
  2. lake_harley
    lake_harley
    To make up for a thinner spring pack on my Model A with a T rear spring, I just cut and tacked some spacers to the top of the clamp bars to reach up into the crossmember to secure the spring. I wouldn't have wanted to loose the drop I was getting by putting a spacer on the top. Seems to be working just fine.
    But, it appears you did a nice job casting your spacer and are pleased with the result.
    Lynn
  3. alchemy
    alchemy
    What are you holding up with that spring? Stock springs have a lot more leaves. Like 8 or 9.
  4. Jethro
    Jethro
    It's going in my RPU....too light maybe?
  5. I had a T spring in my A pick up and didn't like it. I ended up with a Posies reverse eye spring. Rides as good as it can for a long obsolete suspension design.
  6. alchemy
    alchemy
    You need a guy with an RPU to tell you how many leaves it takes. If you are unsure and might want to adjust later, I’d start with a spring with many and remove to taste. The shape of A and T springs prevents sourcing extra leaves from another manufacturer and hoping they fit. I’m pretty sure the Speedway spring is their own design, so Ford leaves might not fit tight.
  7. justabeater37
    justabeater37
    Speedway T spring? Not a T spring. I ran one in the Chari-T. It was about right in a 2100# car but narrower than a stock T spring. I forget what I had to set the perch centers at, but it was pretty narrow.
  8. justabeater37
    justabeater37
    RICH B likes this.
  9. Jethro
    Jethro
    I havent set the perch mounts yet, I'll try and find a stock T spring and measure that.
  10. justabeater37
    justabeater37
    I went back to my build thread. I ended up at 42 1/2"
  11. justabeater37
    justabeater37
    Looks like I ended up at 42 1/2"
  12. Jethro
    Jethro
    Thanks man!
    I appreciate the info.
