Technical Model t rear spring
Discussion in 'The Hokey Ass Message Board' started by 1oldtimer, May 24, 2014.
  1. I had the page bookmarked but it got lost in the shuffle. Is there a problem mounting a T rear spring in an A rear crossmember contour wise. I can twist the frame a little depending on how I tighten the rear clamps (in what order and how hard).
  2. The T spring is not as wide as the A spring. You will need to fabricate a shim/spacer to firmly mount the T spring in the A crossmember.
  3. flthd31
    flthd31
    Yes, there is a much different contour on the "T" vs "A" crossmembers.
    "T" has a much higher arch in it as shown in the pic.
    You could possibly tighten the snot out of the U bolts and get it up there (or crack the crossmember) but the torque required would be tremendous. The A crossmember could fail at some point down the road under such tension.
    A simple fix is to tack a couple of spacers on top the "T" spring to compensate for the difference (see pic). Having an "A" spring for a pattern would help get it right or make a pattern from the inside of your 'A' crossmember.
    Seems most HAMBers don't bother with this and aren't aware that the T crossmember is quite a bit different from an A crossmember. The pic of the "T" crossmember is from Thunderbirdesq roadster build.
    bct likes this.
  4. I did notice that it was touching the center of the leaf only inside the crossmember. I knew about the spacers for the width but didn't see any post or talk about the contour difference. I have both but wanted to use the T spring to lower it, maybe I'll play with removing leafs on the A spring.
  5. Anyone else that has used a T spring have anything to add?.
    HemiIn34 likes this.
  6. flthd31
    flthd31
  7. Meyer
    Meyer
    What about replacing the top T leaf with the top leaf from an A spring? Would help contour and movement front to back also.
  8. 31ster
    31ster
    That's the way I mocked mine up today. Hope it works ok
  9. Here's the 2 rears (model A and model T) together, it's about 1 leaf thickness difference were the u bolts are. You can also see why the T spring lowers it.
  10. ROBERT JAM
    ROBERT JAM
    How many leaves to use on a t spring on a model a roadster? I took two out and it still rides very hard
  11. 100% Matt
    100% Matt
    I make a T-Spring 2.25" wide. I have it posted in the classifieds
  12. dualquads
    dualquads
    I used the same method as this on my A coupe with a T spring, if you don't when you climb in the car rolls to the drivers side quite badly, welding the small wedge shapes made the car sit very level.
    Kev
  13. z28michael
    z28michael
    I'm using a reverse eye T in a model A frame and placed a modelA top leaf on the T spring to fit the A crossmember. Any thoughts on how it will work? Thanks
  14. 1ton
    1ton
    If the T crossmember has a higher arch then would it help to replace the A crossmember with a model t member? Might help lower the car some more as well.
