modern lug pattern on 52 lincoln?
Discussion in 'The Hokey Ass Message Board' started by petebert, Jun 15, 2008.
  1. petebert
    petebert
    i read in another thread that the mid fifties fords have the same lug pattern as ford trucks through the 80's.
    Anyone know if the same is true for a 52 lincoln?
  2. HOTRODPRIMER
    HOTRODPRIMER
    yeah,,,I used a pair of Lincoln wheels on the front of a 65 Ford pickup,,,in fact they are still on that truck,,,HRP
  3. pecker head
    pecker head
    I know 57 Lincolns have truck pattern !
  4. hippie6
    hippie6
    I can put the wheels from my '95 F-150 on my '54 Lincoln. They changed the lug pattern when they went to the new body style around '97 or '98.
  5. petebert
    petebert
    52,53 and 54 should all be the same. But if i measured right, center of thread to center of thread it came in at 5.25. I think all the ford trucks are 5.5?
    maybe my measuring was off, found this on a webpage
    5 on 5-1/2 (139.7 mm)
    AMC - Jeep (5 bolt) '42-'89
    Chrysler - 8 cyl. & wagon '46-'55
    - Imperial '54-'66
    Ford 2 ton van
    Ford Bronco, F100
    Ford - all '28-'48
    - full size P.U., van, Bronco '49-'89
    International Scout, Travelall
    Lincoln - all '52-'60
    Mercury - all '39-'51
    Suzuki - Samurai '86-'89
  6. 55 dude
    55 dude
    bolt circle is 5 on 5.5" common mistake when measuring wheel bolt pattern is measuring "center to center" but you need to measure "center to outside" and your dimensions will come out correct.
  7. cornernfool
    cornernfool
    Same as Ford truck, I'm running 1/2 ton Ford van wheels on mine.
  8. petebert
    petebert
    thanks, does it matter the width are all basic wheels for full size ford truck/vans a good size for a 225/75R15
  9. cornernfool
    cornernfool
    The ones in the picture are 15x6, but I think they also do a 15x7.
  10. petebert
    petebert
    looked into it, the tire mfrs suggest 6-7" wide for a 225/75 or 235/70. I'm going to call the salvage yards tommorrow and see if I can find a set of 15x6's which is the stock size.
  11. petebert
    petebert
    i found 2 5.5's and 2 6" wides. Put the 5.5s up front because they balanced better.
    The backspacing must be different because the 6's leave about 1-3mm between the skirts.
    Heres the close one, it rubs.
