Projects Modern Marmon Herrington
Discussion in 'The Hokey Ass Message Board' started by olskool34, May 22, 2022.
  1. olskool34
    olskool34
    Hi all,
    wondering if anybody has an info on the different frame dimensions for a ‘40-41 ford pickup versus the ‘46-47. I want to build a “updated” Marmon Herrington truck out of my ‘41. The ‘46-7 ch***is is already set up with parallel leafs and it would be easy to just add some axles. I don’t know how easy it is to convert the early truck sheetmetal to the later. Anybody do this before or have hints for me?
  2. Budget36
    Budget36
    Not easily. The 40/41 truck frame narrows to the front a**** other things, the ‘42-7 is parallel.
    But heck, I’d rather see you do that than try an S-10 cluge;)
    Mr48chev likes this.
  3. RMR&C
    RMR&C
    from NW Montana
    I have a'38 Ford truck and was thinking of something similar.....it looks like the challenging part is the front frame/fender mounting area as said above. Wheelbase is likely different as well. I haven't dove into that project yet....
    Keep us posted on what you find.
  4. olskool34
    olskool34
    Thanks for the replies. This will not be some hillbilly built 4x4, it will look like a factory truck. CJ7 axles have the same track width as the ‘40-‘41’s and have a 5 on 5.4 bolt pattern so I could run 16 inch wheels. Fronts would need to be opens up a bit to clear the hub but it is all doable.
  5. 51504bat
    51504bat
    5 on 4 1/2 or 5 on 5 1/2?
  6. olskool34
    olskool34
    Ha, typo. 5 on 5.5
