Technical modern trans for flathead
Discussion in 'The Hokey Ass Message Board' started by clutchlover, Jun 23, 2014.
  1. clutchlover
    clutchlover
    does anyone have some input on what type of modern trans can be connected to a flathead in a 53 ford pu ?
  2. oldsman41
    oldsman41
    they make adapters for f1oo ford 3spd od or s10 t5 or an auto I think c4 ford probably others too
  3. George
    George
    [QUOTE="oldsman41, post: 10483528, member: 117201 I think c4 ford[/QUOTE] Yes, because it has a removable bell.
  4. Lets see, sag 4sp, t10, top loader 4sp, t5's, chev 3sp, ford 3sp, c4, c5, powerglide, ect.
  5. clutchlover
    clutchlover
    thanks any ideas on an adapter source ?
  6. clutchlover
    clutchlover
    Yes, because it has a removable bell.[/QUOTE]
    would prefer 4 sp manual
  7. clutchlover
    clutchlover
    thanks, i want to use a 4 sp manual
  8. George
    George
  9. Offy still makes em available all over
  10. 19Eddy30
    19Eddy30
    from VA
    You said
    MODERN
    LENCO !!:D
    But SpeedWay has a Reasonable $$ kit for C4
  11. Hnstray
    Hnstray
    from Quincy, IL
  12. And ye ol speedway
  13. catfishdog
    catfishdog
    from Miami
    I have used wilcap and corn husker
  14. rlhinit
    rlhinit
    from Wisconsin
    It depends on what t5 you plan on using. If early s10 - it has the GM bolt pattern - some of the later model t5's have a Ford bolt pattern - both adapters can be purchase from CornHusker Rod shop. You'll have to look it up on a Google search. They also offer complete conversion kits. And they are of top quality.
    Rayzo
  15. RUSTY2
    RUSTY2
    from Canada
    put a WCt5 right from Ford it was 1600.00 love the 5 speed
  16. Ole don
    Ole don
    I ran a hundred dollar swap meet T5 from an S 10 on a locally machined adapter on a 49 stamped steel bell behind an 8BA. Speedway sells a like adapter now. I used a second hand ten inch clutch, and a disc from an S10, and a special pilot bearing. The Ford throw out had a sleeve in it to fit the chev tans stem. The chev throw out bearing did not reach the Ford clutch fingers all the way.
  17. olcurmdgeon
    olcurmdgeon
    Buy a small block Chevy used Lakewood scatter shield at a flea market, redrill flange with flathead bolt pattern, get new oilite bearing for flathead flywheel that has Chevy input shaft ID ( I had local cycle shop do it on their lathe for $15), and you now have an adaptor, a scattershield and wide range of 3sp, 4spd, 5spd trans to use! We ran this in our FED and our Anglia for many years behind an 8BA motor.
