Projects Modified Build
Discussion in 'The Hokey Ass Message Board' started by Beau, Feb 1, 2012.
  1. bobadame
    bobadame
    Maybe raise the back of the body an inch and have a look.
  2. daddio211
    daddio211
    FASI, you don't know how close my dad and I came to buying one of your "kits" years ago, then how sad we were when we learned they were no longer available.
    GREAT proportions and seemed like a lot of car for the money! I hope you're doing something similar these days!
    Sent from my DROID device using the TJJ mobile app
  3. Beau
    Beau
    TwinCitiesKnight was kind enough to borrow me a set of 14"x5.60 tires/wheels and adapters so I could have an idea of what the car would look like with smaller diameter tires. The wheels were spaced out a little bit, and I plan to run 16x4 Ford rims, but the general look is there. The car was lowered about 1.5" more.
    I'm in the market for a set of 5" or 5.5" tires now.
    Fasi- I have been making patterns for some sort of belly pan. I'm still not sure which way I want to go. Thanks for posting those pictures.
  4. daddio211
    daddio211
    Yep, you nailed it again! This car keeps getting better and better and better!
  5. ESGEE
    ESGEE
    from Sweden
    Looking good, i would go for 4" insted of 2" but thats me...
  6. hillbilly4008
    hillbilly4008
    Why do those front tires bulge so much? Gotta agree with Daddio, "you nailed it again"
  7. Beau
    Beau
    Thanks Daddio and Hillbilly.
    I noticed that on the tires as well. The sidewalls appeared "stretched" like the rims might be too wide??
    I was also able to get a start on the p***enger side cowl panel. I removed it and blasted it. I have tomorrow off and already warned the lady that I will be there all day. :)
  8. Frenchy Dehoux
    Frenchy Dehoux
    Your project is looking really cool good job Beau.
    Frenchy
  9. bobadame
    bobadame
  10. hillbilly4008
    hillbilly4008
    Yeah, what is the plan for the windsheild?
  11. Me likey!
    Much better with the rubber rake!
  12. twin city knight
    twin city knight
    ****, those tires are a bit bulged...well at least they work for mockup purposes!
  13. dwaynerz
    dwaynerz
    <HR style="BACKGROUND-COLOR: #e5e5e5; COLOR: #e5e5e5" SIZE=1> <!-- / icon and ***le --><!-- message -->
    kinda radialy looking. great work you are doing. i want one of these too, so its time to start scroungin parts. any of your body or frame come with a ***le? the local secretary of state police says illinois is going to begin making it more difficult to get a ***le to something that doesnt have one.
  14. Beau
    Beau
    My first attempt at recreating a panel. This panel goes below the seat. I removed the old Model T panel and started to make my own. The bead roller made this project a nightmare. I found out that they needed to be adjusted a lot, they can cut metal, and they warp sheetmetal! Oh what fun. I had to do a lot of hammering last night. I was able to get it closer to flat, and I put the trans tunnel in tonight. I still have a lot of smoothing out to do. I'll chalk this up as a learning experience. This piece will be hidden so it'll be OK. But I sure learned a lot in the past two days!
    Not perfect...but it's better than what was in there.
  15. Mark Fox
    Mark Fox
    Have a look at mindover3 on YouTube . He goe's by the name Mindover on here.He will show you how to make panels.using only hand tools.
  16. Beau
    Beau
    I actually saw a post on here before referring to his videos. I have watched a few.
    After I got home from the first night of work, I did some research about rolling beads and flanges and found out that I should have stretched the areas I was going to roll. From what I understand, rolling a bead or fange will shrink the metal, and cause flat panels to warp.
    I made a T stake, ******* and a few different dollies using old Irons. I found a leather purse that had a good shape and filled that with sand. I have also collected a lot of different hammers and punches that I modified and cleaned up.
    Here is one of the videos-
  17. Mark Fox
    Mark Fox
    Have a look at www.allmetalshaping.com. If you join there. The guys there are very helpful. If you have any problems.
  18. patmanta
    patmanta
    from Woburn, MA
    Nice job, Beau! Bead rollers can be fickle beasts and have a bit of a learning curve. I still haven't set my new one up yet but I'm not too far off from needing to hopefully.
  19. Beau
    Beau
    So I have been busy the past couple days. I decided to pull the stock seat base parts out of the body so I could straighten them, fix tears and clean them up. Blasting them took forever. I had an orange cloud in the blast box. It was terrible.
    When I was finished blasting it I bolted the pieces back together using the holes from the original rivets. I squared it up and trimmed some stuff up, then tacked it all together and removed all the bolts.
    This will all be covered up, so it isn't real pretty. It's better than the stock **** and will be a lot stronger.
  20. sko_ford
    sko_ford
    That riser will be good for storage & turned out nice
  21. Beau
    Beau
    Thanks Sko. It's just the stock T cleaned up.
    My buddy took some pics the night I started the floor panel. My lady, Alisha, is pretty much at the shop every time I'm working on the car. She is awesome! She is the one that helped me roll the floor pan. Also, if you look closely, she is hiding in a lot of the photos I have posted. She is a Manga artist. When I'm working on the Hot Rod, she is drawing amazing things. She is the best shop mate ever. :)
  22. TexasSpeed
    TexasSpeed
    from Texas
    Wow! I missed this update but that looks right on! This is turning out to be a great little modified.
  23. hillbilly4008
    hillbilly4008
    Beau, that is an awesome photo for so many reasons.
    1. Good lookin' gal bangin' tin out in the shop
    2. Big ol' PBR in the foreground
    3. you wearin' the leather bibs
    4.....
    Do yourself a favor and get a wheel for that bead roller.
  24. Beau
    Beau
    I'm a lucky fella indeed. She is a purty gal!!!!
    PBR is terrible, but if I drink good beer I can't work anymore.
    The apron is from a bicycle company called Electra. It was a fair price and it saves my clothing from getting destroyed.
    I made a new friend with a blacksmith, Hans (http://www.handsofhans.com/) that is close to my shop. I have been trying to learn that side of metal work. Tonight he was at his shop and helped me with a little project I had. I watched a video at some point where Jesse James hammered out a T5 shifter to make it look older. I received a stock T5 from a fella on here using the "Pay It Forward" thread. I dis***embled it and took the arm over to Hans's studio.
    We cut off the threaded section and he put it in his furnace. He straightened it out using a hammer and anvil first. Then he used an old Little Giant power hammer to taper the shaft down for me. I'll use my torch to curve it as needed. He stretched it from about 6" to 14"! He allowed me to give it a try. What a fun machine!
    It started out like this-
  25. Beau
    Beau
    Here are a couple more photo's Hans took. That's an old Little Giant hammer that was made in Mankato, MN
    I will be putting a couple bends in the rod to get it where I want it. I thinks it's pretty cool though! Metal is amazing.
  26. general gow
    general gow
    MODERATOR
    wow! that's so rad!
  27. sko_ford
    sko_ford
    Yeah blacksmiths rule
  28. marx
    marx
    Dammit that shifter trick is cool!
  29. I like the shifter work.(as well as all the other work). There's a blacksmith about an hour from here that I'll have to look up, and see what he can do, just to file away for future reference. I have pictures of my GF, long ago, working in the shop with me, same boots, and almost the same jacket. It's nice to have support like that.
  30. Beau
    Beau
    A propane forge is a pretty simple little devil. I'm going to make one now. With time, most of the parts are probably going to be free. I think I have a bunch of it already. Seems like it could be a useful tool and it would save me from wasting O/A gas.
    I spent the past couple days out of my shop and at friends shops. I wanted some metal shaping mallets but I don't want to buy them yet. I decided to make some of my own. My friends shop has a wood lathe so I gathered two busted baseball bats from a buddy and put them in the lathe. I had never used one before. It's a ton of fun.
    These are the roughed out heads I made.
