Hot Rods Modified Murray - Race to the road! Progress in Review!
Discussion in 'The Hokey Ass Message Board' started by scootermcrad, Jan 19, 2010.
  1. scootermcrad
    scootermcrad
    Since I've got a few on-lookers, here... Maybe someone can answer a brake line question for me.
    I have two fittings in my brake line setup that have NPT threads. Do I use a sealer of some type for these or should I just rely on the taper of the fitting?
  2. panheadguy
    panheadguy
    from S.E. WI
    I'd use a tiny bit of loc***e pipe thread sealer (white). Careful tho not to get inside. It's a teflon lube that hardens over time.
  3. Old SR71 Mechanic told me to use a tiny bit of antiseize.
  4. 562roadster
    562roadster
    Looks awesome Scooter!
  5. -Brent-
    -Brent-
    Permatex makes a pretty good thread sealant.
  6. scootermcrad
    scootermcrad
    I'm going to put the body on momentarily to build the exhaust headers and get my VIN inspection, but then it will come off again to get rid of all that yucky rust and finish up the body work. Inside needs to be painted and doors need to come off for final finish work. Body work also really needs to be done with the body mounted on the frame so the doors line up how they're supposed to and what not. So basically I'll take care of the underside with some stuff Limey Steve from Lime Works recommended, and then back on for final fit, finish, paint, and interior. WOW! That was fun to say that last bit! :eek::eek::D
    Which product. They make a ton! ;):D
    Ya' know, after I read your reply, I think I've heard that before as well. Thanks!
    Okay... have some of that too. Thanks!
    I have a real old frame p***-thru fitting with female 1/8" NPT threads on both ends. So just don't want to make sure I get that all sealed up correctly. Thanks guys!
  7. Crazydaddyo
    Crazydaddyo
    Scott,
    I have a couple of 1/8" npt fittings in my system and I didn't use anything on those. No leaks or problems.
  8. scootermcrad
    scootermcrad
    Thanks Dan! I have it tightened down already without the goop. I think I'll leave it alone and try it first then.
  9. Wow! The ch***is came out great! You have got to be so geeked to be at this point!
    -mikethegreek-
  10. ynottayblock
    ynottayblock
    Awesome scooter. just awesome.
  11. McFly
    McFly
    WOW!! Long time coming McRad! Congrats.
  12. SlowandLow63
    SlowandLow63
    from Central NJ
    Look at you go!!!!!!!!!! Painted and ***embled!! You have a roller my friend!!!!!!!!!! This pic says it all, look at that reflection all sorts of professional-like! Nice job man!!!!!!!!!
  13. dodgerodder
    dodgerodder
    Holy smokes Scott, you got a painted roller! LOOKS AWESOME! I really had fun with that part of my build, it feels really great so finally see all your work come together. It REALLY feels good to actually bolt everything on for the last time-no more mock-up mode:D:D
    Really proud of you bud, I bet you got a huge grin. Your paint work really looks great! What a pain spraying a frame. So many goofy areas to get paint into, and so easy to drag an airline across an area that you already sprayed:eek:
    Now get off the internet & keep it going!
    Dan
  14. scottybaccus
    scottybaccus
    I'm just gonna sit in the corner turning green with envy.... Yipee, Yay Scott! You da man! ;)
  15. scootermcrad
    scootermcrad
    Thanks a TON for all your help and that's a huge compliment coming from you! You've been a huge inspiration and next I get to follow your tech on how to cut runs! HAHA! :D Have one that needs to go. But one isn't too bad considering what a MONSTER pain it was to paint that frame!
    Thanks Dan!!!! I really appreciate it!! I saw your update as well! I need to hurry up! You're beatin' me to the street!! HAHA! :D
    Thanks Scotty!! :cool:
  16. scootermcrad
    scootermcrad
    By the way, I want to send a big thanks to CraigR from Lime Works, for getting those shackles and bushings all set and ready! They are AWESOME! I appreciate your help! And especially thanks to Steve for his time while we were up there. Pictures coming! They were much better than last time too! Stay tuned for those!
  17. Hey dude, can I swing by sometime after work to take a look see? It looks great.....
  18. 41 Dave
    41 Dave
    Scooter, Wish my "A" frame was going together for the last time. Nothing like a freshly painted frame with nicely painted and detailed axles . . . . Mine still has some fab work before we blow it apart to blast the body so body work can be started.
  19. mart3406
    mart3406
    from Canada
    Absolutely fantastic! A definite two thumbs
    up! Please keep the updates and pics coming!
    A suggestion for your consideration too. I
    noticed in the pics, that that to
    accommodate the somewhat 'set back'
    seating position, that the steering column
    *appears* to be extended quite a bit
    rearward, well into the door opening area.
    I was thinking that to ease entrance and
    exit, perhaps the steering column could
    be made telescopic. You could probably
    accomplish this by making the column in
    two pieces, with a hollow outer 'slider'
    tube fitted with internal (female) splines,
    that would slide over an externally (male)
    splined, solid bar-stock internal section.
    The steering wheel hub would attach to
    the hollow external tube, with a transmission
    driveshaft yoke, or the female section of a
    truck 'driveshaft slider' perhaps, supplying
    the internal 'female' splines. This outer tube
    could then slide back and forth as needed,
    over an internal steering shaft fitted with
    matching 'male' splines, that would be
    hidden under the dash. You'd need to
    fabricate some sort of a positive locking
    device to 'lock' the column in the driving
    position once you were seated in the car.
    I think a lock could be fabricated by using
    a spring-loaded pin mounted in the outer
    column that would engage a matching
    groove' machined into the male splined
    section of the internal shaft. With the the
    pin pulled back, the column could slide back
    and forth as needed, to allow for easy exit
    or entrance - and then when released and
    the column extended to the 'driving' position,
    the pin would automatically line up with and
    drop into the groove, 'locking' the column and
    preventing further back and forth movement.
    Mart3406
  20. scootermcrad
    scootermcrad
    Yeah! Tomorrow would be best, or next week if you want to see it with the body on. This weekend my parents will be in town visiting, so I'm hoping to recruit my Pop's to put the body back on with me. He helped take it off the very first time, so that will be a cool moment. :cool:
  21. scootermcrad
    scootermcrad
    Orrrrr.... Just make the steering wheel removable. Which it is! ;):D
    I really don't have any problems getting in and out... YET! If I keep eating the way I have been lately that may all change. HAHA! :rolleyes: Cool idea, just the same! Thanks for the words!
  22. Roadsterpu
    Roadsterpu
    If you need help lifting let me know.
    The ch***is looks great. you ahve done an incredible job my friend. We all should aspire to the have something that looks that good.
  23. Roadsterpu
    Roadsterpu
    That is way to ensure that very few people can get in the drivers seat. Some what of a theft deterrent.
  24. CraigR
    CraigR
    Awesome mate!! Diggin' the ch***is, well worth the effort. Nice bushes too...
  25. scootermcrad
    scootermcrad
    Thanks buddy!!!
    Thanks Craig!! And YES! I have nice bushes! :D
    I ended up just pressing them in the rear spring and letting them deform a bit. Then I reamed them back out. Pretty much went in without a hitch, other than that.
  26. scootermcrad
    scootermcrad
    Parents were in town this weekend. My Dad couldn't wait to check things out. So, while I had him here I decided it would be the perfect time to have him give me a hand putting the body on. He was there to give me a hand when we FIRST took the body off when it still had four doors... So it was cool to have him here to be a part of it. My buddy Erik seems to have impeccable timing as well, and stopped over to drop a couple things off and gave us a hand as well.
    Don't get excited... It's not staying on. I have to take care of ***le and registration ****, build some headers, body shims so the doors line up, etc. Then it comes off to undercoat it and finish some metal work inside and out.
    I'm reluctant to even show these. The body is still very unfinished and the ocean air is REALLY been a battle since I stopped working on it to focus on the ch***is.
  27. Roadsterpu
    Roadsterpu
    Looks really good my friend.
  28. scootermcrad
    scootermcrad
    Thanks Paul!
    I really need this done. Having a "Monday Moment" where everything looks just OFF to me. Going to take a break this week from it to get re-focused. I know things will look better as I finish them and more complete when I finish the exhaust and get the radiator fixed and the grille shell in place.
  29. I know what the problem is....
    ....it just needs body work and some paint. :D
  30. dirthawker1313
    dirthawker1313
    holy s#%$ it looks good with the body on.. !!
