Modified Project update
Discussion in 'The Hokey Ass Message Board' started by buckethead, Sep 5, 2004.
  1. buckethead
    buckethead
    Been working on my project, here's the latest pic's. Used a set of rear springs from a Dodge mini van. I cut and drilled them the correct length and mounted them quarter elliptical style. The mounting box was made with 3/8" plate and boxed with 1/4" plate. I drilled a hole in the end of the spring to keep it from pulling out of the mount, and the clamped it a clamp made frome 3/8" plate.
  2. buckethead
    buckethead
    pic 2
  3. buckethead
    buckethead
    pic 3 I have not decided how to mount the upper control arms on the rear yet. maybe some suggestions?
  4. willowbilly3
    willowbilly3
    from Sturgis
    Since it looks like you may ned to make a driveline hop maybe you could run the upper arms triangulated into the sides of the driveline hoop
  5. buckethead
    buckethead
    pic 4 I found a dropped tube axle cheap and mounted it useing 2 1/2" pipe 3/8" thick walls, 3/8" plate to make the mount.
  6. buckethead
    buckethead
    willowbilly, Thats what I had planned at one time, the side to side motion should not be a problem due to the springs comeing out of the frame. I would like to keep the rear of the car clean and simple as possible. I will try to use some type of friction shocks hidden as best I can.
  7. kustombuilder
    kustombuilder
    from Novi, MI
    make the upper bars (in the rear) look like split bones. in fact use split bones and run em on the outside of the frame. it'll look just a traqnsverse setup would with split bones but the springs are different and the "bones" can be made to pivot at both ends. just a thought...
