Modified Slow build but progressing
Discussion in 'The Hokey Ass Message Board' started by dakotajayne, Nov 20, 2011.
  1. dakotajayne
    dakotajayne
    from 3c1
    Heres a few shots of the 26 modified I started a few years back. The body and rails came from Hot Rod Jim at Lions Hot Rods.They are quality and good to work with.The powertrain is a GT 302, T5, 8.8 Tloc and the rear has been narrowed 4".The front axle and shell are 33.The wishbone is from late 30's Lincoln.Most other components are from Hamb advertisers or my MFG.Sorry about HEI and vega steering(Government Motors) but they were in stock.I will post later if I ever get done.
  2. poboyross
    poboyross
    from West TN
    I like! How did you do that steering setup?
  3. tfeverfred
    tfeverfred
    Nicely done, sir. I'd also like to know more about that steering setup. Is it just two gears turning on each other?
  4. dakotajayne
    dakotajayne
    from 3c1
    The Vega gear turns the car wrong way and wouldnt place the wheel where i wanted. I used two gears to reverse and place it where it is comfortable. It also has a crisp three turns lock to lock. The Vega steering arm is a thing of beauty and the splines had to be repositioned to allow it to hang vertical with the wheel centered. Have fun!
  5. 29HOTROD
    29HOTROD
    from Indiana
    I hve seen this build progress and it is engineered and hand crafted very nicely. the steering is really cool.
