Technical Modified torque wrench
Discussion in 'The Hokey Ass Message Board' started by johnfin, Dec 4, 2025.
  1. johnfin
    johnfin
    from Florida
    If I put a snap on crows foot attachment on the end of a torque wrench will it throw off the readings. I have come across torque specs for fittings on hydraulic lines and such.
  2. oldiron 440
    oldiron 440
    Only if it slips or the tube twist…
  3. Paulz
    Paulz
  4. warbird1
    warbird1
    What he said... ^^^^
    gimpyshotrods and Sharpone like this.
  5. alanp561
    alanp561
    Sharpone likes this.
  6. RodStRace
    RodStRace
    Not sure there is a formula as much as measuring. That's how those torque sticks worked.
    They were varying thickness and would 'flex' less or more when used with an impact.
    https://thegrumpymechanic.com/how-do-torque-sticks-work/
    So I'd guess without testing that it's a percentage, and that it varies depending on the extension.
  7. leon bee
    leon bee
    Does that all change if you orient the crowsfoot differently? Like 90 degrees.
    BigRRR and Sharpone like this.
  8. Sharpone
    Sharpone
    If the crows foot is 90 degrees the torque wrench will read normal.
    IMG_3714.png Found this online , shows what is going on better than I can explain.
    Hope this helps.
    Dan
  9. Sharpone
    Sharpone
    The above diagram is probably not exactly correct because L would be a little longer than shown as I believe L should be measured from the center of the wrench as well as center of the handle but the results are more than likely well within the torque wrenches accuracy range and well within the tolerance needs for our work.
    Dan
    gimpyshotrods likes this.
  10. 57 Fargo
    57 Fargo
    An extension between the socket and torque wrench does not change the reading. Torque is rotational force. Torque sticks are only supposed to be used with an impact.
  11. 325w
    325w
    Been wondering about that for years! Seemed right so I did it anyway.
  12. RodStRace
    RodStRace
    I have often used an extension when torquing stuff. It gets your knuckles up and away from the part.
    If at all possible, I will use that same setup to do all the fasteners in cases like head bolts.
    I have always used the strongest extension I could and used the torque spec laid out.
    My feeling is that even if it's off due to the extension (or not), the main point is to get it close and even.
    If you are concerned with the change using an extension, the wrench better be certified by a machine that has been recently calibrated, too. And the threads and shoulder better be clean and lubed exactly.
    A torsion bar shows that application of force at one end doesn't transfer perfectly to the other, but unless you are using a 1/4 inch drive to torque triple digit numbers, it should be negligible.
  13. Sharpone
    Sharpone
    Using an extension shouldn’t affect the torque it’s static 100 lb ft at the wrench will be 100 lb ft at the fastener even if the extension twist some and it will twist.
    Dan
    57 Fargo and Paulz like this.
  14. Boryca
    Boryca
    from Detroit
    As an aircraft mechanic, this is part of the training. The diagram up top is correct, and yeah, it’s a bit of a pain to calculate. However, as also stated up above, placing a crow’s foot at 90 degrees will not impact the torque reading.
    Socket extensions do not affect torque readings unless they’re real ****ty extensions with a whole lot of twist. If you’re using a high-quality extension, the bolt will give before you twist the extension, ***uming it’s properly sized that is. I wouldn’t be using a 1/4 extension to torque a 1/2 diameter bolt.
    warbird1, gimpyshotrods and Sharpone like this.
  15. Joe H
    Joe H
    What changes with an extension is how much farther around you have to move the torque wrench before the bolt moves, ***uming the extension twists.
  16. Sharpone
    Sharpone
    Yes that is what I was trying to say, the extension , any extension is going to twist some, how much is determined by the force and the strength of the extension but really doesn’t matter because the force will be transferred to the fastener.
    Dan
    Budget36 and gimpyshotrods like this.
  17. Budget36
    Budget36
    I was taught when using an extension, to keep it at 90 degrees to the bolt/nut.
    I can’t recall why, but just remember that tidbit.
    Heck, I don’t even like using a deep socket on a torque wrench.
  18. patsurf
    patsurf
    everyone needs to take a moment to see the diff between vertical and horizontal planes!!
    warbird1 likes this.
