Technical mods - please delete - duplicate thread
Discussion in 'Traditional Hot Rods' started by fur biscuit, Jun 1, 2023.
  1. https://www.jalopyjournal.com/forum/threads/may-2023-may-showers-bring-bangers.1291463/
    Coming Events: (PM Jiminy with additions/corrections)
    Stay safe.
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $34.00 all color except for the oldest pictures (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: jimb4e4@gmail.com
    phone: 951-695-7313.
    A few links to speed equipment companies there may be more
    https://specialtymotorcams.com/index.php#header
    http://www.millerhi-speedheads.com/index.html
    http://www.modelatrader.com/brumfield/brumfield.html
    https://www.hotforhotfours.com/advertisers.htm
    https://www.secretsofspeed.com/speed-parts
    Bert's, Synder's, Mikes affordable also list some speed performance parts.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    Model A & B Style Cast Iron Cylinder Head Compression Ratios.
    http://www.fordgarage.com/pages/headcompressionratio.htm
  2. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
  3. Poor little car was moved with a fork lift a few times and the valence panels showed it. Started uncrumpling. Should be able to save the fronts from both sides.
    stubbsrodandcustom likes this.
  4. BlacktopScraper
    BlacktopScraper
  5. 62pan
    62pan
    Checking in
    Steves46 likes this.
  6. Outback
    Outback
    from NE Vic
    IMG_20230528_145650480.jpg It's looking like I have just bought this 23 roadster body, the price was right, it'll end up on either an A ch***is or a T ala Greg Stokes "Fireball T" nothing else to add. :p
  7. Outback
    Outback
    from NE Vic
  8. railcarmover
    railcarmover
    61F61650-7853-4BB9-9754-58B296A2CB23.jpeg A18E4A35-458A-49CF-B507-0E14F354E806.jpeg
    Fatigue is like rust, ominous and never quits. Sold all my ch***is junk prior to leaving Cali, met some good folks search for a wishbone. Shop exterior done, gas line and heater up next..
    Outback likes this.
  9. Out and about. Still running in the Burtz block for Pendine. At a music festival for the weekend. D08D028B-89A3-4563-AF6D-2D0793EDA1EF.jpeg 338F8412-7999-4777-ACA4-AA5F2DE5FF30.jpeg
  10. denis4x4
    denis4x4
    from Colorado
    The Zipper has a new home after 24 years. Ordered a new long block from Bert's for the '29 CCPU that is my new avatar. 6-1/2" cab extension, T-5 and Jeep seats make it fun to drive.
  11. The37Kid
    The37Kid
    Paul, Outback and fur biscuit like this.
  12. Stu
    Stu
    Newbie here
  13. Stovebolt
    Stovebolt
    Not much news - been busy with life, and getting sorted for our annual holiday. I did manage to pick up a Flathead Ted brake kit, and hope to get it fitted after or break.
    Outback likes this.
  14. Kevin Pharis
    Kevin Pharis
    from Califunny
    See ya on Sunday…?
    25mercury and Outback like this.
  15. The37Kid
    The37Kid
    ^^^^^^^^^^^^^^^^^^^ Please take lots of photos and post them here.
  16. railcarmover
    railcarmover
    Pay attention when fitting the kit, you may have to grind the teds roller track to clear the bottom of the brake shoe on the fronts
    if You didn’t get the deluxe kit for the rears the rear brakes might hang backing up, no worries, once going forward it releases
    Make sure the front adjuster pins slide freely and are greased
    Teds instructions are vague, and certain aspects of the fit up are critical.once you have them dialed in they are great..
    Stovebolt likes this.
  17. I am leaning towards the large slanted louvers at the moment...but the mind may change!!
  18. The37Kid
    The37Kid
    Slanted louvers look fine. I'll dig around and add the photos of the one I had. It is in a fine home in the Lang collection.
  19. Outback
    Outback
    from NE Vic
    @Stovebolt did you get it locally?
  20. Stovebolt
    Stovebolt
    no, but Dave Slater has them in stock
    Outback likes this.
  21. Stovebolt
    Stovebolt
    I appreciate your advice.
    By all accounts they work exceptionally well. I spoke with a guy out here who, on Ted's advice, fitted them to the front of his B roadster, got used to them, and THEN fitted the rear one's.
    Something to consider
    Outback likes this.
  22. Outback
    Outback
    from NE Vic
    Cool. He's just up the road. Didn't think to ask him
  23. railcarmover
    railcarmover
  24. Kevin Pharis
    Kevin Pharis
    from Califunny
    Keep an eye out for this coupester that was stolen from a shop here in Orangevale just a couple days ago…
  25. trikejunkie
    trikejunkie
    from Scotland
    Checking in - windows in ,roof complete ignition circuit wiring done -cars running and steering now , possibly get to drop it in gear mid week and drive it !!!!!!!!!!!!!! OH HECK . coupe outside.jpg windows.jpg
  26. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    How much smoother is the Burtz block vs a stock 3 main?
  27. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Cool *** tub...
