Molasses bath made me a believer !!
Discussion in 'The Hokey Ass Message Board' started by drfreeze, Oct 14, 2009.
  1. drfreeze
    drfreeze
    i will be doing a gas tank in the next few weeks, as for chrome i can't see it hurting it but i'll try to find a rusty chrome part to put it in there.
  2. jimi'shemi291
    jimi'shemi291
    DrFreeze, THX for your thoughts! Yes, I think I'll EXPERIMENT with less important iron-base parts AND something chromed, before taking the BIG plunge!!!
    GREAT THREAD!!!
  3. CADILLAC AL - That's exactly what I've been using for years...from Tractor Supply. I use it full strength, or I use the blast cabinet. For blocks, heads, etc., they go into a steel 55 gallon drum with water, Washing Soda, and a 12 volt battery/batterycharger. I've also tried running the battery/battery charger through the Mik Stone Remover. BLASTS the rust right away.....
  4. J'st Wandering
    J'st Wandering
    I did this also with a flathead, two to be exact. I had the same thing happen to me. The pitting seemed to me to be areas in the blocks where there may have been impurities in the cast iron. It is more than just some small pits. It is like the mol***es is eating into the surface. On my blocks, it happened mostly towards the one end of the deck on one side. I had to have it resurfaced to clean it up. If I did it again I would protect any machined surface with grease or leave the heads on until after it was soaked.
    I soaked a couple of blocks, and a few other items. Now I have a rim in it and it isn't doing much of anything. Probably used up and needs to become fertilizer.
    I used a plastic 30 gallon barrel. If you find the right style, you can cut the top lip off and the top end will fit back into the barrel making a nice cover.
    Just a response on vinegar. I soaked a timing cover for a flathead in vinegar and it made the cast iron soft where I could s****e it off with a screw driver.
    Neal
  5. Verbal Kint
    Verbal Kint
    from Washington
    Do you think it would unstick a motor? I have access to a V8-60 that was used as a ranch irrigation pump and is stuck pretty good, I would like to make it a runner again just for the hell of it.
  6. X38
    X38
    To answer a few questions, I've thrown in rusty chrome pieces and found that the chemical chases the rust, includung where it's porous/rusty under the chrome so you get clean metal where it's bare, chrome left where the base metal is good and flaked off chrome where there was rust under it.
    I've found that rusted up nuts/bolts/bolted together panels/plugs etc are easy to undo after a good soak as there is no more rust binding everything.
  7. RugBlaster
    RugBlaster
    I don't get it....you use the month old mole***es on your pancakes?
  8. draginsteel
    draginsteel
    Sweet Solution to a Nasty Problem.
  9. bdk1976
    bdk1976
    I picked up a Pontiac 455 this summer that had been sitting out in the weather without heads and almost broke my wrist trying to knock the pistons out without much success (broke some of them before giving up and the rings were still fused to the block with rust). Dropped the block in mol***ess mix for a few weeks (about 5 parts water to 1 part mol***es) and when I pulled it out the pistons just about fell out when I tapped on them.
    I've since stripped the block completely and it's now back in the mol***es to finish cleaning it up. I'll try post before/after pics when I pull it back out.
    This definitely isn't something you can do to a complete motor and hope to get running again without a rebuild - as mentioned in previous posts, bearings, pistons, etc. will probably be toast if they are soaked in the mol***es.
  10. Parts48
    Parts48
    from Tucson, Az
    I was going to also..but the wife feel asleep while I was reading this thread...
  11. sixfink
    sixfink
    from Germany
    howdy back there,
    yes, you can treat your chromed steel parts in the mosl***es solution. It will eat on the rust while leaving the good chrome alone.
    We did it on a set of early falcon hubcaps which turned out great.
    No damage to the factory chrome at all.
    Just keep in mind the mol***es won't add new chrome where it had been damaged by corrosion; and such areas will rust again if subjected to moisture and air. Cover the back sides with paint, and apply some wax the shiny outer side to keep it decent looking.
  12. jimi'shemi291
    jimi'shemi291
    X38 and SixFink: Gentlemen, THAT is invaluable info!!! I hope other guys can reference this and SAVE a boatload of dough on rechroming!
    BTW, YES. I do paint exposed steel, and give old chrome a pretty frequent waxing. Maybe my car won't win in a show, but I want it to look decent going down the street AND put of a total re-chrome for a few more years! THANKS again!!!
  13. LOTS of great info!... but my question still remains-
    Will mol***es do damage to valve seats (enough to ruin them) and if so, is there a way to coat machined surfaces so that the mol***es doesn't create pitting?
  14. drfreeze
    drfreeze
    As in my case i'll be putting in hardend valve seats so pitting would not be a problem , but if your not going to put seats in the head a good valve job will clean the pitting up .
  15. rcnut223
    rcnut223
    from wisconsin
    I have a gas tank that sat for ten tears with a few gallons of gas in it. Now it's thick and dried would this do anything to that stuff or any other ideas?
  16. J'st Wandering
    J'st Wandering
    Grind the valve seats after you soak the block, or heads, depending on what you are working with. The quality of the material in the valve seats should not be affected by the mol***es. To protect areas from the mol***es, cover it with grease or vasoline. Something that won't be affected by water. If the mol***es can't get to it, it should be fine. The areas where I saw pitting in the cast iron seemed to be of poorer quality in the metal.
    Neal
  17. 64 DODGE 440
    64 DODGE 440
    from so cal
    If you are concerned about protecting surfaces that you don't want pitted try brushing a coat of rustoleum or other protective paint over the surfaces before soaking.
    Just an idea. I'm going to have to experiment with this process.
  18. Paulie9fingers
    Paulie9fingers
    ... that's funny :D
    nice trick to remember too
  19. themodernartist
    themodernartist
    Mac,
    Two things to remember:
    1. Mol***es only removes the rust.
    2. Mol***es only removes the rust.
    Peace,
    Chaz
  20. jimi'shemi291
    jimi'shemi291
    ModernArtist, and as the other guy pointed out: Mol***es is the ENEMY of aluminum.
  21. Not true . . . and I speak from first hand experience! The pitting I've seen was in non-rusted areas -- even the heavily ported intake ports that we'd just completed and were as shiny as can be.
  22. Dick Dake
    Dick Dake
    Will it remove grease, paint, etc? Or should I soak it in lets say, maple syrup first?
  23. NYfatboy
    NYfatboy
    I have a stuck 39 ford trans,if I soak it in this stuff will it harm the syncros,etc?
  24. echnidna
    echnidna
    from Australia
    mol***es will attack aluminum and zinc including the zinc used to make br***.
  25. unclerichard
    unclerichard
    from Michigan
    I did a '30 Ford gas tank with the 4/1 mix. Filled the tank to the top. Let it set a week. BINGO Nice and clean. Used the feed store mol***es. Its cheap, not toxic, smells nice and it WORKS
  26. Soreback
    Soreback
    1st Mole....... I smell pancakes.
    2nd Mole...... I smell pancakes.
    3rd Mole.......I only smell mole***es
    Couldn't help myself good thread
  27. jimi'shemi291
    jimi'shemi291
    SoreBack! LOL! LONG time since I heard that one!!!
  28. jimi'shemi291
    jimi'shemi291
    Thank the Lord for UncleRichard! Finally, somebody who's done a whole gas tank. Mix ratio and time in bath! THANKS, Uncle! I need to DO this to my DeSoto.
  29. silent rick
    silent rick
    what effect does temperature have on the process. i would like to clean some parts over the winter, but don't want to keep the drum in the garage due to the smell. and there's always the possibility of sub-freezing temps.
