Technical Moon Hydraulic Pedals
Discussion in 'Traditional Hot Rods' started by Moors, Dec 5, 2020.
  1. Moors
    Moors
    from Windsor CA
    I picked up these pedals recently and I want to rebuild one and run it on my roadster pickup. I know these were ran on everything from show cars to all out drag cars but I can’t find much information about these. I’m looking for old adverti*****ts, articles, anyone who has experience running these, rebuilders, advice for rebuilding and possible part suppliers?
    loudbang and Okie Pete like this.
  2. -Brent-
    -Brent-
  3. saltflats
    saltflats
    from Missouri
    I thought they outlawed them in racing.
    loudbang and Moors like this.
  4. jimmy six
    jimmy six
    When the fluid (ATF) got warm to hot your rpm mysteriously went up.:rolleyes:
    loudbang, saltflats and Moors like this.
  5. Moors
    Moors
    from Windsor CA
    I wonder why if that’s true
  6. Moors
    Moors
    from Windsor CA
    Thanks for the link and information Brent. I really dig your 60s model A. I’ve been following it for a while
    Does anyone know anything about bleeding the system? anyone rebuilt them? Mine currently doesn’t work when I press down on it so I don’t believe there’s any fluid left in the line.
  7. -Brent-
    -Brent-
    Maybe no return set-ups? Hydraulic systems don't leave you with any control after they fail.
  8. -Brent-
    -Brent-
    Thanks! I appreciate that!
    I don't know about rebuilds. Out here we have hydraulic shops that build lines and rebuild all sorts of pistons and pumps. I am sure a place like that could point you in a helpful direction. However, with liability and such I doubt anyplace would do anything more than sell you parts.
  9. dumprat
    dumprat
    from b.c.
    It's a small hydraulic cylinder, actually two of them. Odds are solid any local shop worth 2c can rebuild them with stuff off the shelf. I would put something other than ATF in it. There are new synthetic fluids that are not as sensitive to water and heat.
    Hell if you used EPDM seals you could run brake fluid.
  10. Fordors
    Fordors
    Back in 1967 a friend had one on his ‘51 Ford coupe with a 327. He bought it from Moon but the hydraulic cylinders were made by Marbet. Totally unnecessary but it sure looked cool to a couple of 18 year olds.
    Moors likes this.
