Hot Rods Moon Speedometer Cable?
Discussion in 'The Hokey Ass Message Board' started by xderelict, Oct 9, 2017.
  1. xderelict
    xderelict
    Need a parts number for a speedometer drive cable for a 5/8"x 18" thread. It's going to a Saginaw 4 speed transmission. Any help is appreciated. 22308765_1473297779372500_2107495094932102443_n.jpg 22366803_1473297776039167_2508306848289283393_n.jpg
  2. squirrel
    get a speedo cable for a GM car or truck up to the mid 60s, it should fit.
    There are different lengths, you didn't specify, so it's hard to give you the correct part number.
  3. 56shoebox
    56shoebox
  4. squirrel
    yup, but from a style perspective, Lokar stuff and Moon stuff are mutually exclusive, aren't they?
  5. xderelict
    xderelict
    I'd say somewhere in the 60 inch range. The transmission is a 74 Vega 4 speed.
  6. squirrel
  7. 51504bat
    51504bat
    Any good speedo shop should be able to make one to order. Not that many around but there are still some, maybe try a big truck repair shop. I had one made by a local shop to mate the Watson 3 speed auxiliary trans in a '40 Ford big truck I had to a Stewart Warner Speedo no problem.
  8. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
  9. squirrel
    or just drive down to your local parts store and buy one...it's not a special part, by any means.
    Montana1 likes this.
  10. xderelict
    xderelict
    The local parts store wants an OEM application. The speedometer is not OEM. 5/8"x18" thread and a .104 square drive doesn't mean anything to them.
  11. xderelict
    xderelict
  12. squirrel
    Like I said...pick a mid 60s or older GM car. LIke a 1964 Belair, 283 engine, 3 speed transmission.
  13. squirrel
    Are you sure it doesn't have the correct thread? The last one I bought, did...
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    yup. I usually order one for a 55 chevy. 63 inch long. just bought one on rock auto the other day for less than 8 bucks
    squirrel likes this.
  15. that cable that Squirrel gave the part # of CA3002 will work just fine with that speedometer.. go down to an O'Reilly and get one
    why make it harder than it needs to be?
    or..... i have an extra one here , if you want to stop by you can have it
