Hot Rods Moon tank for radiator overflow
Discussion in 'The Hokey Ass Message Board' started by NHBandit, Jan 2, 2023.
  1. Need opinions for using a Moon style Aluminum fuel tank as a radiator expansion tank mounted low in front of the grille. I want one for my street legal 36 Chevy g***er and rather than just sticking it out there for looks I thought about making it functional as a radiator expansion tank. Of course it will be much lower than the radiator cap and the one I'm looking at has a vented cap so that would have to go. What say you all ?
  2. Been done 100s of times.
    mad mikey, VANDENPLAS and NHBandit like this.
  3. SPEC
    SPEC
    It work's perfectly on my sedan.
    mad mikey likes this.
  4. fleetside66
    fleetside66
    Wouldn't a radiator expansion tank or bottle have to be vented?
    seb fontana likes this.
  5. Jkmar73
    Jkmar73
    from Tulare, CA
    I put one on my model a. It didn’t come with a vented cap. It just has two fittings on it for hoses.
  6. Well I don't know which is why I'm asking. Thanks
  7. Vented cap or sealed ? Thanks
  8. Blues4U
    Blues4U
    from So Cal
    It may have been done before, but that doesn't make it a good idea, IMO. I'm not a fan of Moon tanks on street cars to begin with, using it for a radiator catch tank seems kind of along the same lines as sticking Cadillac or Oldsmobile valve covers on a SBC; or multiple carbs with only 1 of them actually functioning, or a fake quick change cover. JMO.....
    VANDENPLAS likes this.
  9. Use a radiator cap designed for a recovery tank. Run a line from the Over flow
    to the bottom of the Moon Tank. Leave the top hose on the Moon Tank open to act
    as a vent for the water coming in at bottom. You can hide it on the back of the
    Moon tank. Works Great. I have used the Moon Tank for a recovery tank on
    several cars. Jerry from North Carolina.
    NHBandit likes this.
  10. neilswheels
    neilswheels
    from England
    mad mikey and jnaki like this.
  11. 1971BB427
    1971BB427
    from Oregon
    It doesn't matter if the cap is vented. But a Moon tank mounted low in front will only work as a catch can, not like a normal coolant recovery tank. So every so often you'll need to top off your radiator, and drain the coolant that overflows into the tank.
    I put a small pet**** on the bottom of mine to make draining it easy. Just check the radiator as you would on any vehicle that doesn't have a recovery tank.
    Ned Ludd and mad mikey like this.
  12. If you plumb it as I said It works just like a normal coolant recovery tank. You MUST use the proper radiator cap for a recovery system.
    Just Gary likes this.
  13. Harv
    Harv
    from Sydney
    If the overflow tank cap ain’t vented, it will pressure up to radiator pressure. If that little Moon tank ain’t rated for the pressure, a kablooie will soon follow.
    For a recovery system (or non-recovery fir that matter) the overflow tank can be as low as you like in a car. As long as the hose tip is in the recovery tank bottom, it will draw fluid. The cooling engine/radiator contents draw a mild vacuum to “recover” the “expanded” fluid back from the recovery tank, uphill into the radiator.
    To make it too low, you would need it to **** about 14 metres uphill. At that point, you need so much vacuum that the water boils at room temp, and won’t draw back. (my 14m may be out by a metre or too… my fizziks is getting rusty).
    Cheers,
    Harv
    oldfordtin and Just Gary like this.
  14. BigDogSS
    BigDogSS
    from SoCal
