MOON tank photo gallery
Discussion in 'The Hokey Ass Message Board' started by Jeem, Aug 25, 2012.
  1. fuel10922
    fuel10922
    Sweet pics...nothing says race car like a Moon tank!
  2. USA Tires Sign Joe
    USA Tires Sign Joe
    from Western NJ
    Here is the one on the front of my car.
    chryslerfan55 and Deuces like this.
  3. Muttley
    Muttley
    Yes
  4. hotroddon
    hotroddon
    My 1960's moon on my 32 Coupe
    Doyle Gammel's
    My Anglia one during the restoration in 2009
    One of the most famous one, Tom McMullens
  5. guffey
    guffey
    5 gallon moon
    Deuces likes this.
  6. rpkiwi
    rpkiwi
    from Truckee CA
    Moon tanks look very cool.Of all those illustrated how many are actually in use and if so what are you using them for.Thanks Roger
  7. lurker mick
    lurker mick
    Mine is an early Moon tank. The tag says Moon Automotive Equipment, 10935 S. Bloomfield ave. Norwalk. It has the small Creighton Hunter roadster tag as well. It uses Eelco brackets
    and I use it as a coolant recovery tank.
    Mick
  8. An early one......
  9. Coolant tank on the tig welder at Mooneyes......
  10. Convex ends are Moon, tapered ends are Eelco....
  11. WZ JUNK
    WZ JUNK
    from Neosho, MO
    This one is on a 32 I built some time back. This car was really low. Funny how I look back at it now, I would change a few things. I wanted the headlights tucked in tight at the time, now I would move them up and out a little.
    John
  12. Old Ford Coupe
    Old Ford Coupe
    Moon Tank is used as my radiator overflow. The spreaderbar is actually a handicap shower handle from Lowes Home Improvement store. :)
  13. PFF
    PFF
    from UK
    I bought my Moon tank at Pomona swap meet back in the 90s for $15.00 with the spinner cap. Those were the days... Billet was king and no one wanted that old junk
    chryslerfan55, pecker head and Deuces like this.
  14. chop32
    chop32
    Another Eelco...
  15. NickJT
    NickJT
    from S.E. PA
    To me the Moon tank is such an iconic piece I had to get one as soon as I had the roadster. Now I'm trying to find a way to make it functional. Since I don't need an auxiliary fuel tank, I'm thinking either use it for overflow to replace what's there now, or if I ever decide to do a traditional ( ;) )twin turbo roadster I would use it for holding meth/water for spraying into the intake for charge air cooling. I got the Moon brackets to mount it on the spreader bar.
  16. Tony
    Tony
    Any of you guy's have an idea of when Moon went from the spring style to the solid ring style holders for their tanks?
    My tank is about 15 years old now and uses the solid style which was what was available through them when i bought it, but i see what look like old tanks with equally old looking solid ring's as well.
    Tony
  17. Sgt._Grumpy
    Sgt._Grumpy
    Folks that "just dont know", ask why I have a little beer keg on my car....hence the sticker!
  18. Muttley
    Muttley
    Right around 1970, my '68 Moon catalog still shows the spring versions.
  19. Steves32
    Steves32
    from So Cal
  20. oldnuts
    oldnuts
    from nebraska
    i love these tanks but does anyone use them for their daily driver or for trips?
  21. Tony
    Tony
    Thank you!
    Cool thread!
    Tony
  22. NickJT
    NickJT
    from S.E. PA
    The tank I posted above I got recently from Moon and it came packaged with the spring style holders but I also got the solid ring ones since I like those better.
  23. 1971BB427
    1971BB427
    from Oregon
    NHRA made the spring mounts illegal, and they went to the solid mounts to meet tech.
  24. verno30
    verno30
    Count me in
    falcongeorge likes this.
  25. scootrz1
    scootrz1
    from usa
    model a fake tank
  26. 32 for me
    32 for me
    from SO. CAL.
    I used some 14 ga. stainless, drilled the lightning holes and the radius for the spreader bar and bent it 90 degrees and welded it up. Mine will be used on the street. I will fill it threw the moon tank then it will be pumped into a 14 gallon tank inside the car behind the rear seat. I didn't want to cut the body for a gas door. The rear frame rails are bobbed.
  27. rramjet
    rramjet
    Before
    After
  28. 354valiant
    354valiant
    from Illinois
    This is my fake non - MOON tank on my '65 HEMI Valiant, it is a Buetsch Racing Ent. special...:D my Dad and I made it from an old Hamm's tapper, we epoxied two aluminum discs we cut from some stamped water heater tanks, bored a hole on the mill for the filler neck which we also epoxied, and tappped a couple of hole for some fake fittings with lines... Thanks Brian and Gordy :)
    Deuces likes this.
  29. Merlin
    Merlin
    from Inman, SC
