I have a recently rebuilt Weiand WPD39 tripower set up for a big block Chrysler. The manifold is in very nice shape, no damage or cracks, all threads are in perfect shape. The setup came off a running 383 so it does have minor crud but is still very clean. This is still a good working setup and ready for fuel! The carbs were all rebuilt using American made kits and set up for today's ethanol fuels. The carbs were setup similar to a Pontiac tripower. The center carb has a new baseplate that was modified for a vacuum port and extended throttle shaft for tripower linkage. Choke still installed. The outboard carbs have also been replaced with aluminum baseplates that have the torsion springs in the linkage, thicker throttle blades hand lapped in for a tight seal, idle & power valve circuits removed. Chokes removed and shafts holes plugged with aluminum plugs. Comes with a nice progressive linkage setup with spherical rod ends and stainless rod with brass stops. Also comes with air cleaners but filters were removed. PM if interested
