Technical Mopar 727 input shaft question
Discussion in 'The Hokey Ass Message Board' started by rjgideon, Jul 6, 2023.
  1. rjgideon
    rjgideon
    I'm in the process of swapping a 1963 push ****on 727 transmission from a 19-spline input shaft to a 24-spline input shaft to allow me to use the later 24-spline torque converters. I pressed both input shafts out from the rear clutch retainer, but didn't pay attention to the oil feed hole orientation on the input shaft just above the splines. Do these need to be lined up or offset 90 degrees? It looks like fluid would run along the channel since the ID and OD are so different, maybe it doesn't matter?
    I looked in my 727 rebuild book and searched online and couldn't find where anyone talks about this orientation for the oil holes.
  2. lemondana
    lemondana
    from Lincoln NE
    Contact A&A Transmission in Camby IN. They are Torqueflight spe******t's. Phone is 317-831-3066. They ought to be able to help you out.
  3. Kevin Ardinger
    Kevin Ardinger
    Or Griner engineering
  4. rjgideon
    rjgideon
    I actually emailed Pat Blais and he said it can go back in any orientation because the fluid runs in a channel and then in those holes. I just lined the holes up and pressed it back together.
    Thanks for the help though!
  5. 73RR
    73RR
    You did good calling Pat. He is well versed in all things TF.
    rjgideon likes this.
