Technical mopar 727 to a518 conversion
Discussion in 'The Hokey Ass Message Board' started by chucksrodgarage, Jan 20, 2015.
  1. chucksrodgarage
    chucksrodgarage
    from wisconsin
    i have a 65 dodge town wagon with a big block mopar and a 727 torqueflite. it is running a dana 60 rear end with 4.10:1 gears. while i love everything about the set up. i also like to cruise at 75-80 mph which is reving the engine pretty high.
    i've been doing some research on the a518, and it sounds like the way to go. near as i can see, a 1988-1994 a518 would be the ticket. haven't decided on electronic or hydraulic yet,
    any recommendations or comments on the 46re versus the 46rh? would like to keep it as simple as possible, but the re does have some advantages (lock up converter).
    as they make so many versions of the a518, what type vehicle should i be looking for a transmission from? it looks also like only the v8 's used the 46r transmissions? and the v10's and diesels used the 47r trans. and the v6"s used a 42 or 44r
    is this correct?
    any comments or suggestions will be welcome..
    Chuck
  2. As far as I know Chrysler didn't make any of these that will bolt to a big block. The bolt pattern is way different than the small block or diesel they were behind.
  3. Terraizer
    Terraizer
    You will have to get a adapter from your big block to the 518's small block pattern, since no 518's have the big block pattern. 1993-1995 46RH's have lockup converters. The RE (1996+) is electric controled and needs a computer to control it, where the 46RH does not need a computer to control it. The 46RH is a better choice conversion wise.
  4. chucksrodgarage
    chucksrodgarage
    from wisconsin
    yes, i know i will be needing the adapter kit. it is around $600.. no problem, and yes i hace decided on the 46rh transmission. they made two different ones of those. one has lock up converter and the other doesn't. i want the lock up. are they the same behind a v-6? or is that a 44rh?
    what year and models would i find these ******s in?
    thanks.
  5. 270dodge
    270dodge
    from Ohio
  6. Frankie47
    Frankie47
    from omaha ne.
  7. ram-rod
    ram-rod
  8. Terraizer
    Terraizer
    1994-1995 Ram pickup or Ram Van will have the 46RH with lockup converter. I think the 44RH is in Dakotas
  9. 73RR
    73RR
    Remember that when mounting the small block trans on a big block you have to remove the dog-leg from block...not everyone likes to do this mod.
    Why not just swap to a 3.54 rear gear? That will drop the rpm by about 500, to around 3100, depending on your tire.
  10. chucksrodgarage
    chucksrodgarage
    from wisconsin
    yea, gear vendors was my first thought. they are a little pricey for my budget. i was hoping to do the complete project for around $1500. a gear venders would be great. as for a 3:54 ring and pinion, that would be another path i was considering, but i love the bottom end with the 4:10 gears. it is a dana 60, so it's a little more than just swapping the third member.
  11. chucksrodgarage
    chucksrodgarage
    from wisconsin
    just what is the dogleg?
  12. I think that means the piece of block that sticks out below the starter. But why it needs gone, I don't know.
  13. This suggestion doesn't always go well with marque purists, but I know a couple of people here that have used adapters to mount the 700R4 behind their mopar engines to get the gear multiplication and overdrive. They also commented that the 700 fit the floorpan not too bad.
    Crew Chief likes this.
  14. chucksrodgarage
    chucksrodgarage
    from wisconsin
    well, i guess i'm safe there. i'm definately not a purist. 700r4 i never thought of. the floorpan i don't think is a issue. this is in a dodge panel, and thewre is a lot of room under there. i'm going to look into that possibility. i have no problem cutting off a chunk of cast iron though. would rather not have to remove the engine though.
    wonder how they mount the star5ter on the 700 r4 application? on a mopar the starter mounts to the bellhousing. on a chevy it mounts to the block. may have to put a crank on the front of the engine to start it.
  15. I'm pretty sure the Mopar starter is used; would bolt to the adapter plate. That's what is done on the Ford to GM trans adapters, too.
  16. 73RR
    73RR
    Correct. The leg occupies the same space where the starter needs to be.
  17. Root66
    Root66
    from Norcal
  18. chucksrodgarage
    chucksrodgarage
    from wisconsin
