Mopar A833 overdrive
Discussion in 'The Hokey Ass Message Board' started by KenC, Aug 20, 2007.
  1. KenC
    KenC
    I want an overdrive for my 56 Dodge Pickup.
    Someone on another board suggested an A833 overdrive would be an easy swap.
    So, where does one look for these? What cars/trucks had them originally? How can I ID one of them as an O/D unit instead of a regular 4 spd?
  2. el Scotto
    el Scotto
    from Tracy, CA
  3. TwinH
    TwinH
    from Finland
  4. stealthcruiser
    stealthcruiser
    A833 is an auto ******, yes?
  5. KenC
    KenC
    Thanks for the link, exactly what I needed!
  6. gahi
    gahi
    from Moab, UT
    overdrive a833 came in alot of the 80's pickups with the slant six. They are a manual trans.
  7. TagMan
    TagMan
    I got the A833 NPG 3+1 I'm going to use on my project, out of an '84 Chevy pick-up. Mine has the Mopar bolt pattern, but I understand that some years had Chevy bolt patterns, too. Here's a pic I took when I first got it, if that'll help......
  8. Kerry
    Kerry
    Not all A833 O/D's are aluminum. I'm running one with a cast case and have a couple more as spare's.
    The ones Chevy ran were called NP440's and do indeed have the chevy bell pattern. I've got a couple of these as well for a future project. All of these were aluminum.
  9. SinisterCustom
    SinisterCustom
    Most are aluminum.....
    Also, the 3-4 shift lever will be inverted.........
  10. Little Wing
    Little Wing
    from Northeast
    Aspens and Volares had them as well
