Technical Mopar Electronic Ignition problems
Discussion in 'The Hokey Ass Message Board' started by George, May 16, 2015.
  1. Rusty J
    Rusty J
    Another possibility to consider is the ignition switch itself. I'm experiencing an intermittent ignition stop and in the process of diagnosing the problem as well. I was told this could be a problem if the contacts inside the switch are worn - not sure yet if these switches are rebuildable. My car has stopped 3 times in the past 3 months very shortly after starting - after a short drive - so coming up with symptoms is difficult. All three times I was able to get the car restarted after a short time of swearing at it. time to run through the check list.
