Mopar Gurus, I need help on a 318-3 set of heads
Discussion in 'The Hokey Ass Message Board' started by MoparMan4GZUZ, Mar 4, 2010.
  1. yardgoat
    yardgoat
    All i see thats diff besides the head and the U shape cut out over the heat cross over is the intake toward the back,is that for a water p***age on the intake toward the rear ? Here is a pic of a 413 chry /eldy manifold,the heat riser in the engines we used to dirt track were filled up with alium.To help keep the fuel cooler.Ithink if your looking for a dependable engine id stay with the motor home style,after all they were built to be super reliable
  2. yardgoat
    yardgoat
    Im sorry the p***age im talking about is on the front ? ,of the intake................YG
  3. George
    George
    What does the p***age do/lead to? Thermostat housing or what?
  4. 73RR
    73RR
    T-stat.
  5. George
    George
    About what I figured, but asked in case I was missing something. Can't tell from pics if they look like a match or not.
  6. robbins
    robbins
    from Missouri
    I realize this is an old thread, but do/did your heads have the huge 18mm(Ford) plugs like ones I have here.
  7. dart4forte
    dart4forte
    from Mesa, AZ
    Best 318 bang for the buck is to use an early J head, LD340, a cam shaft spaced out on the old 68 340 4 speed motor.
  8. robbins
    robbins
    from Missouri
    Done this back in the early 90's with an RV cam that came real close to the stock 340 cam. Best running 318 that I ever owned.
