Mopar guys, I need help tuning a 340.
Discussion in 'The Hokey Ass Message Board' started by Mr. Sinister, Sep 18, 2012.
  1. mart3406
    mart3406
    from Canada
    I agree totally on switching to
    a conventional, either stock or
    aftermarket 180 degree intake
    and on the phenolic spacer too.
    Just be sure to use a proper,
    4-hole spacer, as opposed to one
    of the more common open ones.
    or you will more or less defeat
    and undo the purpose of using a
    180 degree intake. Indecently the
    engine can uses a slightly larger
    carb with a 4-hole spacer too.
    I'm not a fan of the newer Holley
    so-called "Street Avenger" type
    carbs, If you want a Holley, I'd go
    with one of earlier Holley 'standards'
    like the tried and true List-1950 600
    cfm or List-3310 780 cfm vacuum
    secondary carbs - or if you can find
    a good core to rebuild, a 735 cfm
    vacuum secondary carb as used on
    some late '60's hi-per big block Fords
    works really good. Any of these Holley
    carbs though will need some tuning
    and playing with jets and power valves
    to get them to work properly.
    Mart3406
