Mopar Guys - What high amperage alternator do you use?
Discussion in 'The Hokey Ass Message Board' started by rockable, Feb 6, 2012.
  1. rockable
    rockable
    I have a 60 amp Chrysler alternator but with AC and electric fan, I'm going to need at least 80 amps. I like the look of the old Mopar alternator and would like to keep that look if possible.
    What are my options?
  2. 50dodge4x4
    50dodge4x4
    Rock, I believe the early front drove Mopars, say 84 or so with efi, had a 90 amp one that was like the old style Mopars. Had to be one before they went to the Jap alt. I think you have to change the pulley, but there is a puller that works well to remove the pulley, then you can use your old pulley on the new alt, pulleys are a press on.
    Before that mid 80s unit, the only old high amp alts were the huge 100 amp police car style. Gene
    Gene
  3. 50dodge4x4
    50dodge4x4
    Also, i think the alt that was on the 3.9 V6 that was in my 39 coupe was a high amp alt as well and looked like one of the old ones. Gene
  4. rockable
    rockable
  5. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    I got 160 amps.....
  6. rockable
    rockable
    Out of a vintage design looking Mopar alternator? :confused:
  7. I went to www.rockauto.com and looked under a 1979 Dodge D300 with a big block. They list three big Amp altenators..they will fit big or small block mopar engines....I think sometime in the eighties they switch to the Nippendenso style altenator..Maybe around 1986....
    Ac Delco # 3342214 100 Amp
    Bosch # AL528X 100 Amp
    Remy # 20036 114 Amp
    Hope this helps...
    I use a 78 amp from 77 Dodge truck in my 64 Valiant with a small block.....
  8. rockable
    rockable
    I believe those are Bosch alternators, Doc. They don't look the same. I guess 78 amp is as good as you can do with the old design. I'll need to do some siphering and see if that is enough. Otherwise, I'll have to change to something more "modern" to power my niceties.
  9. Dane
    Dane
    from Soquel, CA
  10. Frankie47
    Frankie47
    from omaha ne.
  11. Big_John
    Big_John
    from Upstate NY
    blownhemi48 likes this.
  12. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Some Mopars used Leece-Neville alternators for extra power. Think Police cars, New Yorkers,....
  13. rockable
    rockable
  14. rockable
    rockable
    Thanks for the link. I may buy one of the "blinged up" 80 ampers! :)
  15. Jack E/NJ
    Jack E/NJ
    from NJ
    I think Big John's talking about upgrading your 60A to 80A with the upgrade kit part #HO-7004 on that website.
    Jack E/NJ
  16. Jack E/NJ
    Jack E/NJ
    from NJ
    Or just bite the bullet like I did and get the 3-wire 110-amp 10si clone bling for half the price of the xler clone bling. Doesn't look too bad nestled in there with my 413. Besides, the 10si can be used as a 1-wire, 2-wire or 3-wire setup. http://www.dbelectrical.com/c-8468-110-amp.aspx
    Jack E/NJ
  17. I'm using the 100 amp alternator off my donor 79 cordoba... It is a huge and heavy beast!!!
  18. Big_John
    Big_John
    from Upstate NY
    Buy an upgrade kit and upgrade your alternator to 80 amps.
    Then again... do you really need 80 amps???
  19. the mopar cop cars had a100to 120 amp alt but they are HUGE and require specail brackets
    i have a alt off i believe it was an 86 daytona it looks like an old style chrysler alt and supposedly puts out 86amps
  20. pzookey
    pzookey
    Just a quick question. Has anyone tried the 90 or 120 amp Chrysler Alternators from 87 to 89? They are not common but were used on the trucks with a 2 groove v pulley and are supposed to fit anywhere a squareback fit. I just ordered a 120 amp unit for My Travco Motorhome. I switched to electric fans 3 years ago and since then it eats alternators. I hope this fits the 440 well.
  21. pzookey
    pzookey
    Ok since I did not receive an answer anywhere I ordered a Mopar 50/120 alternator for a Dodge 1 ton truck from between 87 and 89. The mounting points are the right distance apart and although the charging stud will be close to the head it will clear without mods. Just need to get the proper spacer so it is set in place. It does look different from the old round and square back and has an external fan but it is a Mopar part.
  22. pzookey
    pzookey
    Well belt alignment is perfect with the factory spacers and it swings with no interference. The factory adjuster bracket is not long or curved enough. I have ordered a universal bracket for $15 that should work. New bolts are ordered as a spacer on one was seized to the bolt. I will update again as soon as it is up and running.
  23. whateverit takes
    whateverit takes
    from Florida
