Mopar or No Car
Discussion in 'Off Topic Hot Rods & Customs' started by theman440, May 15, 2024.
  1. 65pacecar
    65pacecar
    from KY, AZ
    I think partly to clear the valve cover/head for a larger diameter distributor cap. The pertronix distributor uses a larger diameter cap (than stock) and short shaft similar to stock length and you have to dent or grind a spot on the valve cover for it to fit on the big block.
    Also, two different shaft lengths for B-Block vs RB- Block so maybe it is also for MSD to easily switch shafts depending on the application/order.
    porkshop and Sharpone like this.
  2. RodStRace
    RodStRace
    Agree, head/valve cover clearance.
    Looks like quite the handful, small light car with BIG power!
    porkshop, Sharpone and 65pacecar like this.
  3. 65pacecar
    65pacecar
    from KY, AZ
  4. 65pacecar
    65pacecar
    from KY, AZ
  5. 65pacecar
    65pacecar
    from KY, AZ
  6. 65pacecar
    65pacecar
    from KY, AZ
  7. 65pacecar
    65pacecar
    from KY, AZ
  8. 65pacecar
    65pacecar
    from KY, AZ
  9. 65pacecar
    65pacecar
    from KY, AZ
  10. Deuces
    Deuces
    I read a long time ago that **** Landy lent a hand in the development of the dual plug 426 hemi heads.... I could be wrong on that.....
  11. 65pacecar
    65pacecar
    from KY, AZ
  12. 65pacecar
    65pacecar
    from KY, AZ
  13. 65pacecar
    65pacecar
    from KY, AZ
  14. 65pacecar
    65pacecar
    from KY, AZ
  15. 65pacecar
    65pacecar
    from KY, AZ
  16. 65pacecar
    65pacecar
    from KY, AZ
  17. Mike VV
    Mike VV
    from SoCal
    Hmm, seems a bit too simple...but.
    Thanks all.
    Mike
  18. 65pacecar
    65pacecar
    from KY, AZ
  19. 65pacecar
    65pacecar
    from KY, AZ
  20. 65pacecar
    65pacecar
    from KY, AZ
  21. 65pacecar
    65pacecar
    from KY, AZ
  22. 65pacecar
    65pacecar
    from KY, AZ
  23. b-body-bob
    b-body-bob
  24. b-body-bob
    b-body-bob
  25. b-body-bob
    b-body-bob
  26. b-body-bob
    b-body-bob
  27. 65pacecar
    65pacecar
    from KY, AZ
  28. 65pacecar
    65pacecar
    from KY, AZ
  29. 65pacecar
    65pacecar
    from KY, AZ
  30. 65pacecar
    65pacecar
    from KY, AZ
