Mopar Performance PCV Grommet
Discussion in 'The Hokey Ass Message Board' started by Abolton, May 7, 2012.
  1. Abolton
    Abolton
    from Ontario
    Does anyone know where to get a PCV grommet that will fit mopar performance cast aluminum valve covers.in looking for one that will fit the oil filler...not machine a hole in the blank on the cover..I cant seem to find one anywhere and the dealer cant seem to help me, Any help would be appreciated
  2. 50dodge4x4
    50dodge4x4
    On mine I used 2 rubber gromments, the one that goes in the vc for the air breather fits in the cover well, then inside of that I put the pcv gromet. Its a tight fit but using new soft grommets it worked well for the 5 or 6 years I had the car. Sorry, no pictures. Gene
  3. SlmLrd
    SlmLrd
    from DAGO
    I did the same thing, and it was a tight fit, but hasn't failed me yet.
  4. Abolton
    Abolton
    from Ontario
    thanks guys..I tried the mopar PCV grommet inside a brether grommet..but the fit wasnt tight enough...I tried a few different adhesives but nothing would glue the two grommets together...the pcv grommet from mopar is for a tin cover so its pretty shallow, was the one you guys used pretty deep?
  5. are you trying to use the 70 and older pvc valve? why not just update to the bigger diameter 71 and later pvc
  6. Abolton
    Abolton
    from Ontario
    the PCV valve that im using is about 5/8 diameter...i believe mid 70s dodge, the breather grommet is approx 1 1/8" maybe even a little bigger ( Im not there to confirm), I was trying to find a bigger PCV valve, or an inline PCV or a PCV that has the tabs like an oil filler cap but have had no luck.... and Mopar around here anyways is absolutely no help to me...even though they sell the valve covers...they are a real bear to remove now that the engine is in to have a new hole machined in the knockout
  7. BronxMopars1
    BronxMopars1
    from Bronx, NYC
  8. Abolton
    Abolton
    from Ontario
    thanks ill try em
  9. ArchangelKustom
    ArchangelKustom
    from NR/OH
    Ditto on Mancini, or maybe Summit Racing. There used to be a prepackaged set of valve cover/pcv grommets sold through under the Direct Connection label
  10. BadgeZ28
    BadgeZ28
    from Oregon
    Moparts.com might have them
  11. b-body-bob
    b-body-bob
    moparts.com isn't a dealer, it's a message board
  12. Abolton
    Abolton
    from Ontario
    who would think Chrysler wouldnt be able to supply something as simple as a grommet for parts that they market and distribute as their own....as much as I am a big fan of the pentastar ..this has been a bit frustrating :)
  13. i ran a pair of the black cast mopar perf alum covers and had no trouble with a gromment for the pvc ????????
  14. Dane
    Dane
    from Soquel, CA
  15. Abolton
    Abolton
    from Ontario
    ordered from summit..ill try those..Chrysler shows that # dicontinued
    Thanks for your help
