Mopar push button dash control id help
Discussion in 'The Hokey Ass Message Board' started by T Achilli, Apr 14, 2013.
  1. T Achilli
    T Achilli
    from walworth
    5 ****on shifter controls I've had this in a box of parts I can't remember application. I believe it is mid 50s but maybe someone might recognize it.... The switch has only one wire and is grounded to frame.
  2. dart165
    dart165
    maybe 59 dodge?
  3. Chrysler cars went to dash mounted push ****on controls in 1957. Plymouth, Dodge, Desoto and Chrysler had the cluster style as shown. Imperial's push ****ons were mounted vertically slightly curved following the curve of the dash instrument panel.
  4. T Achilli
    T Achilli
    from walworth
    Hard to see but top row has 2 centered next to each other. 2 nd row has 2 far apart and bottom row has one off to right. I know some of ****ons have offset.
  5. ram-rod
    ram-rod
    There's no park lever so it has to be pre 63 that's when the alloys came in, with park.
    Reverse light switch has to be 59 or later. I hope this helps.maybe you guys had reverse lights on early upmarket models
    I think all the selectors were the same. The plastic ****ons provided the different,dashboard designs
