Mopar standard trans info needed
Discussion in 'The Hokey Ass Message Board' started by takid455, Feb 28, 2011.
  1. takid455
    takid455
    Looking to find makes and models of Moapr vehicles that had the BW T-8x trans w/ OD (R-7 to R11) mated to the 354 Hemi.
    Purpose of inquiry:
    I have a 56 F250, T85/9 w/ R11 and a 354. I wish to retain the 3 on the tree b/c its cool and utilize items I have if possible. I aim to locate a stock bellhousing as I believe a 3 spd w/ OD was use behind the 354 in stock applications. From the picture, it also had the E-brake mounted on the rear of the trans as does my 56.
    IF you know info of what makes and models had this combo and or their current whereabouts , please post or PM.
    thanks
  2. 73RR
    73RR
    The standard 3-speed was used in Dodge and Plymouth, but finding the holy grail might be easier than an actual 354 with 3speed.
    Generally, Mopar transmissions in the 1950's p*** cars used a very long input shaft (even longer than an A-833) so that the std bell will not accept a ford/gm trans with a much shorter length input. The truck bells are shorter and vary with the year/trans/application and you 'might' find one that could be used but it will be bulky. Mother Mopar did not skimp on the iron in the old days...
    If you want/need to use what you have then compare your input shaft length to the later ford/gm lengths. If it is similar then consider using an adapter to mount a gm bell and then modify it for the ford trans. No, we do not offer gm adapters.
