Mopar starter motor dilemma
Discussion in 'The Hokey Ass Message Board' started by rockable, Feb 18, 2012.
  1. rockable
    rockable
    I have a 360 engine, ax -15 transmission, and a mini starter I have installed in my 41 Plymouth. The mini starter interferes with my steering shaft u joint. Is there another "inline" motor that will work and that is not offset as much? I've really painted myself into a corner on this one.
    Thanks for your help.
  2. 73RR
    73RR
    I do believe that the 'mini' is as small as a starter will get. How about a pic?
  3. George
    George
    On my '48 plym I moved the coloumn left a bit....
  4. rockable
    rockable
    Here are some pics I shot while doing the build. I didn't realize the Borgeson joints were as large in diameter as they are. There is not enough room between the starter and the frame for the joint to fit. :(
    I'm not sure what I'll do from here. Perhaps, notch the frame...........I'm not loving any of the options I have.
  5. anteek
    anteek
    Offset the engine/trans to the right a few inches. ford pickups in the '70's were offset from the factory.
  6. need louvers ?
    need louvers ?
    Ya didn't off set that engine to the right a bit, did you?! How about dropping the base of the column down and going out beneath the starter?
  7. 73RR
    73RR
    Can you shift the rack over an inch?
  8. farmer12
    farmer12
    Or move it forward and angle it down slightly?
  9. rockable
    rockable
    I need more space between the frame rail and the starter motor. Moving the rack won't help. :(
  10. BuiltFerComfort
    BuiltFerComfort
    Can the Borg. joint be moved up or down to give you a shaft, not a joint, in the starter area? Maybe add another u-joint? Just guessing, may not work. Otherwise notch the frame, not fun.
  11. 48 Chubby
    48 Chubby
    Yes. What he said. A straight coupling should be small enough to fit in the space you have. This would let you move the U-joint back past the starter.
  12. rockable
    rockable
    I think I have it worked out. The real problem was I was having to use a double u- joint on the rack in order to be able to bolt the end of my steering column to the floor.
    If I use a single u- joint on the rack, I can get the joint on and have room for the shaft to p*** between the starter and the frame. The down side is, I will have to make my steering column a "shorty" and extend the shaft through the floor at a lower position and use a longer shaft. By doing that, I can get by with two single u- joints.
    Compromises,compromises, compromises..... :)
  13. farmer12
    farmer12
    All part of the game Rock! Glad you found the solution.:)
  14. Mr48chev
    I'd say that 90% of your problems are that you bought into that theory of "all the cool guys run mini starters so I need one too".
    Here is the stock Mopar starter on the 360 in my 88 Dodge van. Note that the body of the starter is above the bottom bolt and above the bottom ear of the bellhousing. It also sets even or slightly above the step in the pan that goes over the crossmember. I can go out and measure how deep the pan is there but I think pulling the mini starter off and putting a stock starter back on will cure most of your problems.
    OOPs your photos were from the top
    This one is the one on the van from the top. I don't think it sticks out as far as what I see on the mini starter as it sits. I'd do as someone else suggested and see if I could reclock the mini starter to get some clearance where I needed it.
  15. rockable
    rockable
    Thanks. There is no easy fix here. I would have to re-do my exhaust if I used your starter. I'm going with my change in the steering column. I'm pretty sure it will work out fine. Thanks again.
  16. Finadk
    Finadk
