Technical Mopar torque converter question
Discussion in 'The Hokey Ass Message Board' started by rocknrolldaddy, Dec 5, 2016.
  1. rocknrolldaddy
    rocknrolldaddy
    I have a 1954 Dodge Royal, original 2-speed automatic transmission. I did an engine swap a couple years ago, and put in '59 Poly, out of a Plymouth Fury. I used the Poly converter, and starter along with the motor.
    The starter took a ****. The gear in the starter got stuck, didn't return and partially grinded the teeth off the ring gear on the torque converter. My starter rebuilder has been great and replaced the gear on the starter, with a larger one, several times. None have worked, I'm ***uming the teeth are too far gone on the converter. I'm looking to replace the converter, but every where I look seems to skip that particular year. My question is, what converters are interchangeable with this? Or if there are other options.
    Thanks in advance. Art.
  2. 73RR
    73RR
    turboroadster and loudbang like this.
  3. rocknrolldaddy
    rocknrolldaddy
  4. rocknrolldaddy
    rocknrolldaddy
    So...I guess it wasn't as hard to find as I thought. It's hard to find individually, and especially separate. But, found a local shop that said it's not a problem, at all. [emoji28]
    Sent from my LG-H631 using The H.A.M.B. mobile app
  5. countrytravler
    countrytravler
    What did you end up doing?
