Technical More Dash for the Rambler Nash Flathead 6
Discussion in 'Traditional Hot Rods' started by gearguy, Dec 30, 2013.
  1. gearguy
    gearguy
    Elsewhere I posted about finding a stash of old car magazines [1952-1962] along with a nice copy of Fawcett's 1955 How to Build Hot Rods. HAMB member G***erHenry from Sweden requested info on speed parts for his Nash 6 & the Fawcett book had a 6 page photo spread on hopping that motor up. Kosmic Karma required that it be scanned and e-mailed to him so I thought I'd post it here so it is searchable in the future.
    My father once installed headlinings at the Milwaukee Nash plant & my good friend Gregg Kishline is the grandson of Nash Chief Engineer Floyd Kishline so I guess this info was meant to come my way.
  2. Rusty O'Toole
    Rusty O'Toole
    Very interesting, be even better if they were right way up.
  3. gearguy
    gearguy
    Sorry about that. They looked good on my end.
  4. I posted photos of rambler finned aluminum twin carb head brand new old stock
    Salem speed shop
    Salem oregon
    Have no idea if it's still there
    He had a couple packard straight 8 heads too
    I'll see if I can find photos
  5. Hi.
    Did u find the pics or have you missplaced them? U got a number to the shop that had them?
    Thanx
  6. farna
    farna
    Edmunds made finned twin carb heads for the Nash Rambler L-head six. They boost compression, so you need one made for the size engine you have. Compression just goes up to around 8:1, nothing huge, but if you put an 8:1 172.6 head on a 195.6, the small chamber will boost compression a bit more. I don't know how much more, but it will go up. The last 58-65 195.6 models were already at 8:1 compression -- the first 1941 172.6 was only 6.87:1.
    Three sizes were made -- 172.6, 184, and 195.6. Bore (block) was the same at 3.125". Size was altered by using a different stroke for each -- 3.75", 4.00", and 4.25" respectively. That was unusual, especially since they used forged cranks and rods. Would have been cheaper to cast the block with a different bore. All the cranks interchange, by the way, and the block can be bored at least 0.125". Finding a piston might be tough, but boring a late model block 0.125" and using either the 3.75" or 4.00" stroke crank would make the engine turn up quicker.
