more opinions please - narrow buggy spring
Discussion in 'The Hokey Ass Message Board' started by 63dan63, Jan 25, 2008.
  1. 63dan63
    63dan63
    I am in the process of updating the drivetrain in my 1931 Model A coupe. I have a rear-end from a 1993 S10 Blazer 2x4 ready for the swap. The original rear perches are 49 1/4 inches apart. I will not have that much space with the S10 rear (maybe 44 to 45 inches).
    Can I, should I, have the original buggy spring narrowed?
    Can I use a spring from another year to fit and achieve the correct ride hight?
    Does some one sell a narrowed buggy spring for this application?
    Thank you for the responses earlier today. I just do not want to fix a $100 problem with a $300 solution.
    I am leaning toward using a swap meet spring from another year.
    Does anyone know which year might work?
    All suggestions are welcome.
    Thank you.
    <!-- / message --><!-- sig -->
  2. Mr48chev
  3. bushwacker 57
    bushwacker 57
    Speedway catalog has spec for spring and perch position. no cost. find a spring shop - trailer - repair - black smith. A friend of mine had same problem with his A main leaf . he tryed eaton. did not work out.
  4. RichardW
    RichardW
    I had the same problem, wanted to run the buggy spring only narrower. Well, it didn't work out after having a new main leaf made and it not being done well ended up with coilovers. Not telling you what to do but for me it was a waste of money.
    Where is Keller? You can have a look at this one if you want.
  5. 63dan63
    63dan63
    thank you for the posts. I fixed the problem by buying a 1968 8 inch rear end at the dfw swap meet today. Anyone want to buy a very nice S10 rear end???
