more simple TECH front spring
Discussion in 'The Hokey Ass Message Board' started by Paul, Apr 19, 2004.
  1. Anderson
    Anderson
    That is EXCELLENT. Exactly what I'm going to do with mine. How exactly did you get that hole that the bones slid through the exact shape?
    I was gonna get another bone, cut it off up front, and make a pattern.
  2. Paul
    Paul
    Editor
    bradberry00, measured at top of bolt 36-1/4", and center to center of eyes 29-1/4"
    Kustoms&Rockets,
    just measure and fit the plywood pattern first. the hole is 1-1/2" x 2-1/2" with 3/4" radius top and bottom (more or less, a little flatter on the bottom than the top because of the way the tube was formed)..
    Paul
  3. Paul
    Paul
    Editor
    one more just cuz..
  4. Kilroy
    Kilroy
    from Orange, Ca
    I need this info right now and it would be a great addition to the Tech Archive.
    Let's move it on over...
  5. Rolf
    Rolf
    Very nice, and good clear pix.
  6. joeycarpunk
    joeycarpunk
    from MN,USA
    Cool tech. Nice job.
  7. Paul
    Paul
    Editor
    holy ****!
    look at the date on this one! 4-19-04!!
    where the hell did the time go?
    I took a couple months off this time last year and spent a few weeks of it throwing the modified together,
    went back to work and haven't had a good solid block of time to really get anything done, on it or anything else... having a job sure gets in the way of building ****
    I did just scrounge up enough steel to build a frame table, hopefully in the next week or two I can build it so I can weld the frame up nice and efficient like.
    Paul
  8. 67Imp.Wagon
    67Imp.Wagon
    Nice brackets. I like them. What did ya use to cut the actual bracket with.(not the hole) That 1/2 inch is thick.
    It would take me a week with my tools.
  9. curbspeed
    curbspeed
    Paul, Just one question. Is you wishbone upside down? I thought the welded seam was supposed to go on the bottom. I guess it doesn't matter if it works. Job looks good as always. I'm not picking your work but I thought I would mention it.Keep up the awesome work. You'll be going in no time!
  10. brokenspoke
    brokenspoke
    How about posting a full size pattern??
  11. Paul
    Paul
    Editor
    this was a one-off bracket.
    the pattern is long gone.
    after three and a half years and close to ten thousand miles I must say it has proven itself as a sound design though.
    my exact pattern probably wouldn't work with your ch***is anyway,
    you will need to design yours to work with your own axle, frame, spring and 'bones.
  12. Neophyte
    Neophyte
    This is why I love this site and also another reason why one should be patient and try and look at as many ways of doing something as possible.
    I really like this design of yours. I'm close to having to mount my front spring and now that I've seen this I like it the most of all I've seen! I wasn't too keen on drilling through the bones as I couldn't really get my mind wrapped around how to put in a tube for the bolt safely and neatly. This way, by changing the layout, I can also get the bush sleeve lower very easily. I'm using a stock '38 Ford axle so I'm using all the other available ways to get the front end low.
    BUT, first I need to get the wishbone to axle bolts/pins loose so that I can actually pull the split bones apart.
