More traditional billet
Discussion in 'The Hokey Ass Message Board' started by Jethro, Jun 7, 2007.
  1. Jethro
    Jethro
    It's been raining and I've kept busy in the shop whittling some "traditional" billet pedals. I made a similar set last year but my aluminum stock was only 3/8 inch and I had to drill a hole for a countersunk bolt to hold it to the pedal arm. I found some 3/4 stock at the s**** yard and milled some diamonds in the face then I cut them in circles and tapped the back for a 3/8 stud. They might be a little small only 2-3/4"diameter but they should work good.I've got a nice set of 39 pedals for them to go on.
  2. chaddilac
    chaddilac
    sweeeeeet job yo!
  3. daddy-o63
    daddy-o63
    nice job canuck
  4. 29bowtie
    29bowtie
    Those are great,any plans on making any for sale?
  5. HemiRambler
    HemiRambler
    Lookin' good! I wonder how they'd look if you relieved teh edge making them appear thinner on the outside but leaving the center thick for the stud.
  6. Jethro
    Jethro
    I like that idea! ...Maybe try it out...thanks!
  7. 29-a-freak
    29-a-freak
    dude they look awsome!
    great job...
  8. Kevin Lee
    Kevin Lee
    Super Moderator
    Those are great - and I agree with trying to thin down the edge. Really neat stuff.
  9. Jethro
    Jethro
    New and improved....howzat look?
  10. Burgy
    Burgy
    that looks quite a bit better, not so chunky anymore
  11. HemiRambler
    HemiRambler
    I like it!!! Looks even better now!
  12. speedtool
    speedtool
  13. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Very nice indeed.
  14. Wyle E Coyote
    Wyle E Coyote
    Sweet!
    How did you make the diamond shaped pattern? I saw the other post for the gas pedal and they pattern was different.
  15. Jethro
    Jethro
    I've upgraded to a bridgeport mill. I set the quill at 45 degrees and run a bunch of cuts then I turn the piece 90 degrees and cut some more...works a lot better...but a table saw makes a cheap milling machine for aluminum too.
  16. Wyle E Coyote
    Wyle E Coyote
    I figured as much. Nice upgrade...
    Can't wait to have one in my shop.
  17. speedtool
    speedtool
    You could just buy a 2 flute cutter already cut into (or sharpened into) a 45 degree cutter. That way you can leave the head dialed in.
  18. Jethro
    Jethro
    This mill I have has a horizontal cutter on it too. I was wondering if there was a multi cutter like a gear hob that would cut several grooves at the same time so it would go quicker....You ever heard of or seen such a beast?
  19. what fenders
    what fenders
    stack the cutters with spacers between them on the horizontal shaft
  20. speedtool
    speedtool
    Yeah - it's called gang milling. Good for a production run of them.
  21. 50flathead
    50flathead
    from Iowa, USA
    I learned machining with aluminum before anything else. We didn't know enough to call it billet. That makes it traditional for me!
  22. RichFox
    RichFox
    I like your pedals and thought I would horn in with some billet of my own, if you don't mind.
  23. Jethro
    Jethro
    Hell Yeah!...wow that is nice!
  24. RichFox
    RichFox
    Thanks. I had a guy get on me about using Billet at the Hop Up Magazine 100mph club hot dog roast for using billet. What else I could have used is beyond me.
  25. tdoty
    tdoty
    Jethro ispired me to try some homemade billet too.
    The diamond pattern can also be done on the table saw, just like the waffle pattern. Just set the blade at a 45 degree angle and just barely bring it up through the table. I did several test cuts to get the height right. Lacking an Incra jig, I just used the fence and moved it over 1/8" between cuts. It is nice to have a good saw with a good fence :)
    I also cheated, and hole sawed my blanks out of 3/8" thick 6061. I'll run a countersunk stainless allen bolt through the center to fill the hole........................
    Jethro's "Beverly Hillbillet" always makes me chuckle.......I don't know who Beverly is though, so I guess mine would be Ghetto Hillbillet.
    Thanks for the inspiration, Jethro!
    Tim D.
  26. speedtool
    speedtool
    One of these days I'd like to mill a head for a flathead from billet just as a challenge.
  27. RichFox
    RichFox
    Me too. Oh wait. I already did that. this one is on a '32 Plymouth. For my next act I think I'll do a '26 Dodge.
  28. tdoty
    tdoty
    Added pics above.
    Tim D.
