More wiring ?'s for my 440
Discussion in 'The Hokey Ass Message Board' started by BETHELBOB, Apr 27, 2009.
  1. BETHELBOB
    BETHELBOB
    You guy's gave me some great info on my ignition system wiring, i am putting a 440 in an rpu, how about the alternator? It's a 3 wire set up, motor manuels are all about the original car in which it was in, not a hot rod, where does the 2 wires go to from the voltage regulator? Any help would be great.
  2. BETHELBOB
    BETHELBOB
  3. mikeinkc
    mikeinkc
  4. BigBlockMopar
    BigBlockMopar
    That's for a 'newer' style alternator and voltage regulator.
    If you have an old-style (pre70), you'll need this diagram:
  5. I would run the later model dual field alternator with the electronic voltage regulator
    Here is a much simpler wiring diagram
    bigblockdart.com
  6. fourspd340
    fourspd340
    Here's a diagram for both the solid state regulator as well as the old style regulator.
    Stan
  7. BETHELBOB
    BETHELBOB
    thanks again! i think this will help alot.
