Projects Morris Minor Altered
Discussion in 'Traditional Hot Rods' started by RigorMorris, Apr 4, 2017.
  1. RigorMorris
    RigorMorris
    Oh forgot.. what are the dimensions on your radiator
  2. dana barlow
    dana barlow
    from Miami Fla.
    Stock wheel base,dose look good to many,but fact is that short wheel base mixed with big HP= really bad control under max power/driver can't drive straight....... Longer WB fixs the control thing,but to some that have not raced much at all,it may look bad to them. Too those that have drag raced more then just playing around,long WB looks way cool an fast ! Back in 1964 our club built English Ford 105E powered by sbc,made it to the drags first time with stock WB. After 3 club members gave it a go,all 3 nearly crashed an could not do a full run. Yes they were good drivers and one was our FED driver. We took it back to club garage an added 4feet to WB out front. Made good full runs after that.
    RigorMorris and loudbang like this.
  3. RigorMorris
    RigorMorris
  4. southcross2631
    southcross2631
    It is a radiator out of a late 80's Honda Civic. I will measure it this afternoon when I get home from work. It was an ebay special radiator and fan combo for less than a hundred bucks DSCF3491.JPG . Seems to work .
    RigorMorris likes this.
  5. ramblin dan
    ramblin dan
    508.jpg Is this considered altered?
    Glitchy, RigorMorris and loudbang like this.
  6. Peanut 1959
    Peanut 1959
    Is it "altered"? Undoubtedly. Is it "an altered"? Absolutely not! But I'm pretty sure you already knew the answer to both of those questions!
    [emoji12]
    ramblin dan and loudbang like this.
  7. southcross2631
    southcross2631
    No , that's some douche bag who put a Morris minor body on a Jeep frame or some other short wheelbase 4x4.
    loudbang and RigorMorris like this.
  8. RigorMorris
    RigorMorris
  9. RigorMorris
    RigorMorris
    Looks good! I have a brand new Griffin I think may work that I bought cheap.
  10. RigorMorris
    RigorMorris
    This was definitely my worry & reason for wanting to run altered WB.. Still might? Just don't know how it would look parallel leaf setup.. ? I'll Do some more searching and digging of vintage short WB g***ers.
  11. RigorMorris
    RigorMorris
  12. RigorMorris
    RigorMorris
  13. southcross2631
    southcross2631
    You could ,but you would be comparing apples to oranges. There is a Morris Minor now that is running in A/Gas in the Southeast G***ers. You may want to contact Earl McLamore his car is as fast as any of the A/Gas cars ,he just hasn't figured out which direction it is going fast in.
    You can stick a transverse leaf spring or coil over axle out close to the front and gain some wheelbase.
    Anglia's are around 92 inches after they are set up. The Morris is 87inches , so if you push the rear back a couple and the front forward a couple you have an Anglia.
    short wheelbase cars are all about trying to control the violence in the first 60 feet. Then say a quick prayer and hang on.
    RigorMorris, wingnutz and saltflats like this.
  14. RigorMorris
    RigorMorris
    I’ve been thinking going full altered moving the rear axle back and not running rear fenders and a big tire in the back .. pushing front axle just in front of the body.. kinda compe***ion coupe-ish
  15. RigorMorris
    RigorMorris
  16. RigorMorris
    RigorMorris
  17. RigorMorris
    RigorMorris
  18. RigorMorris
    RigorMorris
    Need to move axle back a little and get a different offset wheel to get more tire under the body.. but definitely would look early sixties experimental..
    AHotRod and loudbang like this.
  19. RigorMorris
    RigorMorris
  20. RigorMorris
    RigorMorris
    Was thinking about using Wheel Vintiques 15x12 or 15x14 steel wheel custom back spacing
  21. RigorMorris
    RigorMorris
  22. RigorMorris
    RigorMorris
    a 15x14 inch wheel with 7.5” back spacing would do the trick
  23. southcross2631
    southcross2631
    I like it . There are no rules, build it to please you and screw the rest of them. It's your car and you are not building for a specific cl***, just an era.
    FlatJan and RigorMorris like this.
  24. 6sally6
    6sally6
    Yeah........what he^^^^ said!
    6sally6
  25. RigorMorris
    RigorMorris
  26. RigorMorris
    RigorMorris
  27. 6sally6
    6sally6
    Never drag raced a Morris Minor.......heck fire I never even drove one but can imagine the first 60 feet COULD be a hand full! Couldn't you sorta "walk into it" instead of ....'side-step-it-at-7 grand?!
    Of course its going to rear up like a spurred buck'in horse when you stomp-it. Adjustment-adjustment-adjustment on the suspension and wheelie bars.
    If those mega-thousands of HP funny cars can get a straight(pretty straight) run I bet you can too!
    6sally6
  28. RigorMorris
    RigorMorris
    Probably take it easy till I figure out what its going to do.. lol
  29. RigorMorris
    RigorMorris
    [​IMG][​IMG]
    Getting the finish welding & fish plating done on the frame this weekend.
  30. RigorMorris
    RigorMorris
