Morton & Brett
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by AC1503, Feb 18, 2010.
  1. AC1503
    AC1503
    Hello everyone,
    I'm from southern Indiana, and recently found this forum while searching for Morton & Brett heads & engines.
    My only old vehicle is a 1926 Graham Brothers/Dodge fire engine. It has a Prospect (Ohio) Fire Equipment Co. fire truck body, two chemical tanks, and a Deluge rotary pump.
    The truck's engine had been replaced with a 1970s four banger before I got it. It did come with the old engine and transmission. I don't know anything about their condition. The engine has a cast overhead valve cover that says Morton & Brett, Indianapolis. I have read that they made heads for a lot of engine manufacturers and even made Indy cars & engines. Also that they made a conversion head for Dodge Bros. engines.
    Toms Dogs likes this.
  2. blt2go
    blt2go
    welcome from oklahoma. good luck with your squirter.
  3. Beta
    Beta
    from Central WI
    Welcome from WI!
    -You lower that thing yet?
  4. MN Stumpjumper
    MN Stumpjumper
    Welcome, I saw your name and had to check it out. They also made a conversion for the Ford bangers. You should check out the monthly "Banger Thread"
  5. farmer12
    farmer12
    Welcome from the Netherlands!
  6. 4-port Riley
    4-port Riley
    Morton & Brett made a lot of stuff for T's, speedster bodies, underslung parts, etc., and an OHV conversion for the T block. When the A came out they modified their OHV patterns to fit the A block. When you look at the bottom of the head you can see where they changed the large water p***age at the rear of the head. The head had an intake p***age on the right side and an "internal rams horn" (internal manifold) that actually entered the cylinders from the left side. Later heads had that same p***age plus 2 inlet ports on the left side. They were the first OHV conversions for the A on the market.
  7. BOWTIE BROWN
    BOWTIE BROWN
    fire !!!! Glad to have ya on the board ....enjoy.
  8. themoose
    themoose
    Welcome from Connecticut
  9. big bad john
    big bad john
    ......Welcome aboard.......enjoy the H.A.M.B....
  10. Total Performance
    Total Performance
    from Nor Cal
  11. I just bought a Duece Coupe with a Morton and Brett engine in it.
  12. pprather
    pprather
  13. Toms Dogs
    Toms Dogs
    from NJ
  14. ROADSTER1927
    ROADSTER1927
    Welcome from Wisconsin and just for the record we REALLY Like PICTURES !
  15. Just.dale
    Just.dale
  16. clem
    clem
    original poster had 3 posts in 2 days …………15 years ago !
    Probably not coming back ………..:(
    Just.dale likes this.
