Technical Most Common Wheel Bolt Pattern during Our Era?
Discussion in 'The Hokey Ass Message Board' started by Ned Ludd, Nov 18, 2022.
  1. Ned Ludd
    Ned Ludd
    What would you say was the most common wheel bolt pattern during the HAMB's focus era? 5x4¼"? 5x4½"? 5x4¾"?
    Or perhaps a decade or even two decades later? I suspect that the range a**** US manufacturers remained pretty much constant for a long time, until they went to large front-drive cars in the '80s, with 5x100mm and such patterns.
    The reason I ask: if I had no prior constraints as to a bolt pattern, which bolt pattern would give me the most wheel options in, say, a '60sish idiom? Then I could research and spec my hub/axle details according to that.
    The automotive world is indeed going to hell in a handbasket, but there are occasional glimmers of light a**** the doom and gloom. One is the use of 5-bolt wheels on smaller cars, probably because it is today considered quite acceptable for a small car to weigh as much as a main battle tank. It means that there are at least a few raidable bits and pieces available at parts counters.
    Chucky likes this.
  2. Budget36
    Budget36
    Well, Ford was predominately (as I see it, probably wrong) and was the wide, the 5 on5.5.
    LOU WELLS and seb fontana like this.
  3. Elcohaulic
    Elcohaulic
    5 x 5 and 5 x 4.75 covered everything I ever owned in fifty years.
    Bob Lowry and Ned Ludd like this.
  4. GTS225
    GTS225
    First, Ned, let's define what you mean by "HAMB's focus era". The lug patterns you mentined are typical for 50's, 60's, and 70's era cars. From my, (and I suspect other's), viewpoint, the HAMB focuses on 20's through 50's era cars, with half of the 60's thrown in.
    You're leaving out many patterns from the 20's and up.
    Just sayin'.....Roger
    Elcohaulic likes this.
  5. X38
    X38
    Ford bolt patterns. Because hot rods were Fords.
    manyolcars, clem, RmK57 and 7 others like this.
  6. '29 Gizmo
    '29 Gizmo
    from UK
    5x5.5. Old skool ! A shame this pattern is not retained by early ford based rods in favour of later chevy and ford PCDs.
  7. goldmountain
    goldmountain
    No real winner here. There was also the Chevys with their 6 on 5 1/2" to confuse the matter.
  8. fastcar1953
    fastcar1953
    your building a car around a bolt pattern?
    clem and The Shift Wizard like this.
  9. You tell me what's your favorite "gotta have it" rear axle/differential this imaginary future build will have and I'll take a poke at suggesting a wheel bolt pattern to look for.
  10. Elcohaulic
    Elcohaulic
    I always liked the pattern and look of the small Dodge 340 Duster steel wheels of the sixties.
    Of all the stock steel wheels, I think the Big Ford 5 x 5-1/2 wheel looks the best, the Big Ford steel wheel with it's 5.5 is the best looking and strongest. I wonder if Kelsey Hayes made the Ford wheels too..
    The all out best looking factory wheels were the 1960 to 1968 Pontiac 8 lug wheel with its big aluminum drum..
    SS327 and '29 Gizmo like this.
  11. 5x5.5
    5x4.75
    Gm 6 lug
    Mopar and ford 5x4.5
  12. If you're building your car around tthe wheels then show 'em who's boss and use knock-offs. Just remember the lead mallet.
    VANDENPLAS and Ned Ludd like this.
  13. MeanGene427
    MeanGene427
    from Napa
    One that made me laugh, the '64 Falcon Futura ragtop I just sold was a 260 V8 car, and had original 13" 5x4-1/2 wheels with dog dishes
    deathrowdave and Ned Ludd like this.
  14. goldmountain
    goldmountain
    This has got me thinking why did I go with a 5 on 5 1/2" pattern on my T coupe? Can't see the lug nuts
    with the Merc hubcaps on. I had to redrill the Buick front drums anyhow. All my other cars have a 5 on 4 1/2" pattern and I could have gone that direction to switch my wheels around for a different look. Dumb move.
    Elcohaulic and Ned Ludd like this.
  15. studebakerjoe
    studebakerjoe
    Depending on years Im thinking either 5×5 1/2 because so many Fords were built or 5x4 1/2 because later on Ford used that pattern as well as many Mopar, Hudson, Amc, Studebaker. I think obviously many 5×4 3/4 on many GMs.
    Ned Ludd likes this.
  16. earlymopar
    earlymopar
    "Fords were built or 5x4 1/2 because later on Ford used that pattern as well as many Mopar, Hudson, Amc, Studebaker."
    .......and early Volvo. I know because I took the 10" slicks off of my brothers 65 A990 Plymouth and put the wheel/tire combo directly on my 59' Volvo with Chevy running gear in roughly 1968.
  17. This ^^^... Ford used the 5-on-5.5 from '28 through '48 on almost everything and it hung around on trucks into the '90s. That's 60+ years, it has to be the hands-down winner for longevity. Almost the same goes for the 4.5-on-5. Ford switched to that for their cars in '49 and pretty much everyone used it through the '50s and beyond except for GM. This pattern is still being used on some cars. There's a smattering of 5-on-5s mixed in here and there with each of the big three using it on select car lines at one time or another. The 4.75-on-5 was late to the party in the mid-50s, but GM's sales dominance put it on the map quickly.
    Ned Ludd and Hnstray like this.
  18. KenC
    KenC
    Agree with the 5on4.5 being in the running, and add the fact that Dodge, Plymouth used 5on4.5 from the 30s into the 80s. Along with Stude, Nash, Hudson.
    Hnstray and gimpyshotrods like this.
  19. If you do a wheel search by bolt pattern on Summit and restrict it to 15" wheels, the results are a bit surprising...
    4.5 on 5 12,046
    4.75 on 5 10,533
    5 on 5 9,322
    5.5 on 5 5,570
    Looks like the 4.5 on 5 is the clear winner.
  20. As far as commonality, the 4.5 is used on several non-domestic makes. That bolt pater is super easy to find wheels, however the vast majority don’t fit here.
    Most of my rides have been 5x5.5.
    I’ve got stude, ford and mopar wheels in 5x4.5.
    I can put a 30s mopar wheel on cars made today. But I wouldn’t recommend it :)
    I guess that’s the longest running, current bolt pattern I can come up with.
    the 4.5 and 5.5 along with the gm 6 lug span the bulk of the HAMB era.
    ffr1222k and Truckdoctor Andy like this.
  21. wheelkid
    wheelkid
    Alliance Vendor
    from Fresno, CA
    5 on 5.5" for 40s and 50s era, 5 on 4.5" for late 50s and 60s.
  22. Bandit Billy
    Bandit Billy
    Everything I own is 5 X 4 3/4, I build them that way so I only have to have one set of paint rollers and one mini spare for trips. Plus I have a lot of GM wheels in stock and I can switch em around. Never had anyone want to measure my nuts at a car show...well there was this one girl
    Ned Ludd and Budget36 like this.
  23. DDDenny
    For the most part I'm a child of the late 50's/60's and a Chevy guy, mostly 64-67 p***enger cars so in my little world it was 5 on 4&3/4" bolt pattern, did have a 65 Malibu with an Olds/Pontiac rearend, that was 5 on 5" pattern.
  24. Dave G in Gansevoort
    from Upstate NY
    Big GM were 5x5, and it became the standard for NASCAR up until this year, and their screwup of a center lock hub. Jeep used it on the CJ5s, and I think Ram trucks have used it for a bit. Not sure of that one tho...
  25. X-cpe
    X-cpe
    In my experience, when buying used (esp. aftermarket), 5x4 3/4 were the most plentiful and cheapest.
  26. tubman
    tubman
    Late Ford (4 1/2X5). Back then, I had a '52 Ford and a '55 Dodge that were both kinda' "sketchy". I'd swap tires and wheels between them weekly. The only problem I had was that the Dodge wheels needed tightening weekly when I out them on the Ford. One time, when I was really desparate, I went to the local junkyard and got a wheel off of a Jaguar (of all things), and it fit!
    (Rambler wheels fit too.)
  27. Squablow
    Squablow
    I'd say most of the old custom wheels and stock style steel wheels I've collected over the years were 4 1/2 and 4 3/4, with some 5 and 5.5 inchers thrown in although those tend to be all stock steel wheels. In my experience, more 4 1/2's turn up than 4 3/4's but by a slim margin.
  28. 31Apickup
    31Apickup
  29. Does the F-100 (and F-150) use the 5x5.5 pattern? I’ve only owned a couple of cars in my life and they were Chevrolets, so my common pattern has been 5x4-3/4. Most of what I’ve owned have been Ford Trucks.
  30. Up until the mid 90s on the Ford trucks. Some very early 80s has 5x4.5. Those 9inch rears are great finds.
    I guess most of what we call custom wheels showed up about the time 5x4.75 was used by gm and Ford cars started using the 5x4.5 more.
    dang those goofy small mopars.
    Jeep also shared the 5x5.5 as well. Explains all the aluminum slots in that pattern
    Ned Ludd and Truckdoctor Andy like this.
