Most readily available flathead model?
Discussion in 'The Hokey Ass Message Board' started by EW57, Aug 9, 2010.
  1. EW57
    EW57
    from midwest
    Greetings, I’m pipedreaming on a new project & wanted to know what would be the most readily available flathead engine, preferably a four cylinder, pre mid 50’s. I suppose it wouldn’t necessarily have to have been used for an automotive application, (stationary, generator, implement, etc) but definitely something commonly found in the Midwest. Thanks & take care.
  2. walls
    walls
    I would guess a model A engine. Millions were made, or is that too pre-mid 50's? Does it have to be a 4 banger? alot of ford v8's obviously and dodge six's.
  3. hotrodjeep
    hotrodjeep
    Jeep/Willys 134 Go Devil. Came home in all Jeeps till the 60's.
    Gotta be in the Top 5 produced, with How many went to WWII and Korea?
    The Jeep 134 was basically the same as the willys cars going back to the '20
    and also shares alot of history with the Continnental "Red Seal" engines.
    Jeff
  4. pasadenahotrod
    pasadenahotrod
    from Texas
    Model T or 28-34 4 cylinder would probably outnumber all other 4 cylinders.
  5. You want a car engine.
    There are plenty of Hercules, Waukesha, and other industrial engines around, but they make poor automobile engines. They are set up to run all day at a predetermined speed. The cams, ignitions, hell practically everything, is pure industrial. Four cylinder flathead, yeah the Jeeps are probably the newest, the Model "A" is the most numerous and has a lot more hop up stuff available
  6. 1952henry
    1952henry
    The venerable IHC Green Diamond flat six was Willys design that IHC bought and used from '33-'49.
  7. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    Mopar flat 6s.
    1939 - 1960s
  8. Bearing Burner
    Bearing Burner
    from W. MA
    There were 28 million model T's made. All 4 cylinders.
  9. Who built the other 13 million? Ford built 15 million
