Technical MOTOR, 348-409 Information
Discussion in 'The Hokey Ass Message Board' started by JohnnyB327, Nov 7, 2005.
  1. JohnnyB327
    JohnnyB327
    Bore - 4.125"
    Stroke - 3.25"
    Rod Size - 6.135"
    Firing Order - 1-8-4-3-6-5-7-2
    Weight - 645 Pounds
    Forged Crank - Round flywheel bolt flange
    Crank mains - 2.4977"
    Pushrod Length - Ex. 9.140" IN. 8.772"
    Pushrod Diameter - 5/16"
    Dipstick - Driver Side (Passenger Side on trucks)
    Ignition Timing - 4 degrees before top dead center
    Spark Plugs - AC44(Standard) AC45(Hot) AC43(Cold)
    Spark Plug Gap - .035"
    Rocker Arm Ratio - 1.75:1
    Internally Balanced
    409:
    Bore - 4.312"
    Stroke - 3.5"
    Rod Size - 6.0"
    Weight - 645 Pounds
    Forged Crank - Bell Shaped Flywheel bolt flange
    Crank Mains - 2.4977"
    Pushrod Length - EX. 9.140" IN. 8.772"
    Fuel Pump Pushrod Lengh - 5.75"
    Dipstick - Passenger Side
    Spark Plugs - AC43N (standard) AC44N(Hot) AC42n(Cold)
    (more coming in a few minutes)
  2. JohnnyB327
    JohnnyB327
    Interchangable Parts:
    Part Small Block Big Block
    Points Yes Yes
    COndensor Yes Yes
    Distributor Cap Yes Yes
    Rotor Yes Yes
    Vaccuum Advance Yes Yes
    Distributor Gear Yes Yes
    Rear Main Seal No Yes
    Timing Cover Seal Yes No
    340HP 409 Valve Springs Yes No
    Connecting rod bearings No Yes
    Oil Pump Shaft No Yes
    Oil Pump Yes No
    Oil Filter Cartridge Yes Yes
    Oil Filter Canister Yes Yes
    Fuel Pump Yes No
    Fuel Pump Mounting Plate Yes No
    Fuel Pump Pushrod Yes Yes
    Water pump bearing Yes No
    Water Pump Seal Yes No
    Water Pump Impeller Yes No
    (more coming)
  3. JohnnyB327
    JohnnyB327
    Casting Numbers:
    Blocks:
    3732755.....348......59-61
    3732811.....348......58
    3751872.....348......58
    3755011.....348......59-61
    3771705.....348......59-61
    3782012.....348......58-61
    3788068.....409......62-63
    3795623.....409......61
    3798962.....348......62-65...Truck
    3815707.....348......58-61
    3830814.....427......63......"Z11" (4.312" bore x 3.65" stroke)
    3830814.....409......63-64
    3839752.....409......62-63
    3839754.....409......65
    3844422.....409......63-65
    3857655.....348......62-65...Truck
    3857656.....409......64-65
    3860386.....409......62-64
    3860387.....348......58
    Heads:
    3732791.....348......58-60
    3758379.....348......59-61...250 hp
    3759256.....348......58
    3759332.....348......58-60
    3764702.....348......60......Truck
    3767738.....348......59-60...250 hp
    3781147.....348......60-61...HiPerf, 2.06"/1.72" valves
    3795586.....348/409..61......HiPerf, 2.06"/1.72" valves
    3814690.....409......62-63...HiPerf, 2.19"/1.72" valves
    3815857.....348/409..58-62...Truck
    3819333.....348/409..62-65...HD Truck
    3830817.....409......63-65...340 hp
    3837731.....427......63......"Z11" (4.312" bore x 3.65" stroke)
    3852583.....409......63-65...HiPerf, 2.19"/1.72" valves
  4. JohnnyB327
    JohnnyB327
    http://img.photobucket.com/albums/v428/johnnyb327/Topv-cover.jpg A valve cover with a low spark plug holder is from a 348 tri-power
    http://img.photobucket.com/albums/v428/johnnyb327/2ndV-cover.jpg a high valve cover holder is from 348 and 409 motor (less tripower) built between 58 and 62.
    http://img.photobucket.com/albums/v428/johnnyb327/3rdv-cover.jpg 63-65 all 409's used valve covers with a high spark plug holder featuring a plastic fixture.
    http://img.photobucket.com/albums/v428/johnnyb327/4thv-cover.jpg Truck engines used the valve covers with the spark plug fixture thats near the middle.
    http://img.photobucket.com/albums/v428/johnnyb327/5thv-cover.jpg Hi-po 409s built between 62 and 65 featured the internal oil drippers.
    That's all
  5. JohnnyB327
    JohnnyB327
    Actually thats not all sorry....Right as I pressed that I thought I would add a tips section when building....
    With the truck engines, since they have the notch in the cylinder, bore them to not only add more piston area, but to also fill that notch more.
    The ports are pretty small on a lot of the heads, so match port them with the intake and exhaust manifolds.
    Oh yeah, add as many cubic inches possible!:D
    John
  6. KnuckleDragger
    KnuckleDragger
    Cool info on the W block, I am going to have to save this thread so i can print it out when I get home.
    Jonney
  7. Squablow
    Squablow
    I was not aware that so much of the distributors were the same, considering the distributors themselves will not interchange. I'll have to remember that for my motor.
  8. chromedRAT
    chromedRAT
    not important, but the 348 figures on stroke are off i think. as listed, it gives ya like 440 ci. bore looks right to me, but stroke oughta be around 3.25 or therabouts. the rest of the info is much appreciated. i love W blocks.
  9. JohnnyB327
    JohnnyB327
    whoa shit I fucked up on the stroke....sorry guys
  10. attitudor
    attitudor
    from Finland
    Thanks, good info for fresh W-engine owner like me!
  11. Thirdyfivepickup
    Thirdyfivepickup
    Yeah, this will be saved. Any good ideas for combinations on making 500hp (ish) without having to claw some hipo heads out of a hoarders hands???
  12. Fat Hack
    Fat Hack
    from Detroit
    Also worth mentioning as a 'spotter's trick'...348 engines have the oil dipstick on the driver's side, where 409 engines have it on the passenger's side. Makes it easier to distinguish the two motors at a glance...especially when that "409" at the swap meet ends up being a 348 truck engine!
  13. Good piece of advice for car engines, but I've got a late 348 out of a motorhome that has the deep pan and dipstick on the passenger side. Best thing to do is check the casting numbers. Pans can get changed. Not that an original 409 pan wouldn't be a good score at a swap.:cool:
  14. Early 58 blocks and heads made after 58 WONT work together without some modification. In 58 the factory added some meat on the outside of the sparkplug area of the head, In 59, they added waterpassages with corresponding holes in the block. the late 58 blocks had extra meat on the outside and you can drill out the water holes to match those in the heads. On the early blocks, the holes in the head hang OVER the edge on the block deck!
    I made mine work by welding the 4 little holes in the heads.
  15. Rolf
    Rolf
    Great post, Johhny and good info T-man.
    I am collecting parts for my Impala to do a 348 4sp conversion down the road.
    This thing followed me home the other day:
  16. Tim
    Tim
    from KCMO
    whats this doin way back here?
    to the TOP!
  17. JohnnyB327
    JohnnyB327
    Bore a 409 .030 and then put a 454 crank in it. Port match the heads and intake. Get a isky cam and then run it. I think the final CID is close to 477. So 500 horsepower wouldn't be too far off
  18. igorw
    igorw
    July 2001 issue of R&C had a good article titled "Mighty Fine 409" that was about pulling 500 ponies out of the engines. If anyone wants a copy I'll see if I can make a pdf file out of it to send out.
  19. Thirdyfivepickup
    Thirdyfivepickup
    YES! :D (please)
  20. Dat Dirty Rat
    Dat Dirty Rat
    Man,,,awesome info....I heard that alot of stuff was interchanable,,,but you just never know sometimes..I had a 348 w/3 deuces that i planned on putting in my Model A but had to switch things up...Kind of wish i didnt get rid of it....But i guess i will find another one someday...lol
    But i'm about to burn these printers up at work now...Thanks for taking the time to post this info!
    Dirty
  21. Me too. That would be great. Thanks.
  22. JohnnyB327
    JohnnyB327
    that would be great!
  23. Igorw,
    Thanks for the E-mailed article. I found a link to it in the net also. Here it is.
    http://www.348-409.com/literature/cc409story.html
  24. Brad54
    Brad54
    from Atl Ga
    You have a choice here with the stroker kit: You can either turn down the mains on the crank, or align bore the block/main caps. When making this choice, as yourself this: if you were putting that 454 crank in a 454 block, would you turn one down that far? The answer is no.
    Bore the block and caps. Or, more to the point, ditch the 2-bolt caps, add ProGram 4-bolt caps, and then align bore them. To quote Lamar Walden, "If you just turn down that crank and keep the two-bolt mains, that crank is going to whip around down there like a licorice stick." You'll end up with a broken crank.
    Comp makes really good cams for these engines, too. And they've got much more modern lobe profiles available for even more power.
    -Brad
  25. OK, so I got a 3830814 block stuffed with pistons with no heads. How do I know if it's a 427????????? It's got a 61 crank....oh well...
  26. BLOWER!!!
  27. Thirdyfivepickup
    Thirdyfivepickup
    Anyone make a blower intake for one?
    (and I have zero machining skills. I can't even cut a 2X4 straight.)
  28. mojo66
    mojo66
    I know somebody that does...
  29. Brad54
    Brad54
    from Atl Ga
    WHO?! (really, you couldn't just post it? You gotta make me ask?!)
  30. JohnnyB327
    JohnnyB327
    check the bore! I'll bust out the 427 bore info for ya in a few minutes
