I'm not new to the hobby but new to hot rod's (32 high boy clone). My experience is with corvettes and tri five chevy's so information would be helpful. I'm trying to install the front engine brackets on the frame (sbc with TH-350). I have a Kiwi frame whick is very similar to a socal. I need some pictures and or measurements on where to put them. HELP
You'll want to consider having your firewall installed, mock-up motor (with water pump, distributor, transmission, and whatever header your going to use.), and radiator installed, with the ch***is at whatever rake you want the car to sit at and build the mounts to those specs. Tradrod, (Steve)
