Technical Motor Mount Bushings - Alternative to Speedway Style
Discussion in 'The Hokey Ass Message Board' started by midnightrider78, Mar 2, 2023.
  1. midnightrider78
    midnightrider78
    I can't remember where I bought the side mounts for my '56 Chevy. But, they are the style shown on Speedway's site(a**** others). Due primarily to the horsepower(I'm ***uming) the mounts have continued to squish a little over 1,000 miles or so. When I installed everything, I had a half inch or a little over between the bottom of the fuel pump and a bolt. Now, I have maybe an 1/8".
    I thought I read somewhere about there being a stiffer an alternative to these bushings that wouldn't squish out so much.
    Any ideas where to find said alternative?
    Here is a picture of the mount type and bushings I have.
    Screenshot 2023-03-02 at 12-10-27 Speedway 1955-57 Chevy Car V8 Motor Mount Kit.png
    Thanks in advance
  2. Tim
    Tim
    from KCMO
    I’ve seen people use hockey picks but they get pretty stiff.
    the speedway brand picks are notoriously ****. Maybe give cory a call at RJays in missouri he’s got the good ones last I checked
    da34guy likes this.
  3. TA DAD
    TA DAD
    from NC
    You might look at some Ford or Chrysler strut rod bushings
  4. 31Apickup
    31Apickup
    I’ve seen recommendations before to use the Bob Drake ones instead.
  5. 62rebel
    62rebel
    Take your measurements to a big truck dealer; Kenworth uses a similar design, so does Freightliner and a couple of others. 1800lb diesels smush insulators too
    Desoto291Hemi and alanp561 like this.
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
  7. el Scotto
    el Scotto
    from Tracy, CA
    They're available in polyurethane too!
    lippy, alanp561 and nochop like this.
  8. I have ones from Flatattack racing they were sold by reds headers, but not anymore...seems someone state side can cast or machine some.
    alanp561 likes this.
  9. gene-koning
    gene-koning
    2nd Ch***is Engineering.
    I use their poly mounts on almost everything. With the bolt through, I also use the nylon lock nuts rather that any sort of lock washer.
  10. Bugguts
    Bugguts
    I just ordered these tonight from Roadster Supply shop after searching the net for answers. They have a metal band around them that is supposed to strengthen them and help with squashing. They look just like Bob Drakes. Time will tell if they are better. 20230302_202913.jpg
  11. They are
  12. bill gruendeman
    bill gruendeman
    I have had ch***is engineering one in my car for ten or fifteen years and no problems yet.
    hidez57, seb fontana and rockable like this.
  13. da34guy
    da34guy
    X 2 hockey pucks
  14. swade41
    swade41
    from Buffalo,NY
    I have the ch***is engineering with the stainless band under my big block for many years and they are holding up fine
    gimpyshotrods, Tman and seb fontana like this.
  15. wheeltramp brian
    wheeltramp brian
    I've used the Bob Drake's mounts exclusively as they are the only ones that hold up, the speedway ones and other off brands do just smoosh apart. The ones from RJ's Speed Shop are polyurethane and are pretty nice also, I just got those in the front motor mount kit for a small block Ford
  16. Bandit Billy
    Bandit Billy
    When only the best will do
    ramblin dan, Johnny Gee and alanp561 like this.
  17. midnightrider78
    midnightrider78
    Ordered the Ch***is Engineering ones last night.
    Thanks!
    gimpyshotrods, swade41 and pprather like this.
  18. ramblin dan
    ramblin dan
    These were on my 58 Rambler super six. Don't know how they would hold up on a V8. 1959 -1963 motor mount with part number in background.jpg
  19. Dan Hay
    Dan Hay
    I know I’m late to this party but they need the steel band around them to keep them from squishing. I think I got mine from the Early Ford Store, or Drake.
    Tman likes this.
  20. swade41
    swade41
    from Buffalo,NY
    I had a friend whittle these out for me when I put the "iron lung" on the big block, guaranteed not to squish
    INVISIBLEKID and midnightrider78 like this.
  21. krylon32
    krylon32
    from Nebraska
    I have used a lot of the Biscuits from Roadster Supply. Seem to be good quality.
  22. rockable
    rockable
    Another vote for Ch***is Engineering, now owned by Heidt's.
  23. jaracer
    jaracer
    When I was putting my ch***is together I looked at a biscuit type mount, but I thought about the time and money put into the stock engine mount. I built some frame brackets that allowed me to use the stock engine mounts. I'm quite happy with the setup. Here's what they looked like when I was in the construction phase. 2014_11_18_0342.JPG
    indyjps likes this.
  24. krylon32
    krylon32
    from Nebraska
    I think Heidt's and Roadster Supply biscuits all come from the same supplier in China.
  25. KevKo
    KevKo
    from Motown
    I wouldn’t use hockey pucks, they are HARD, there would be no cushioning at all.
    I’m a goalie, I know how hard a puck is.
    gimpyshotrods and Tman like this.
  26. '29 Gizmo
    '29 Gizmo
    from UK
    The other to think about is lateral stiffness. You need to consider up to 1G braking and cornering forces that means horizontal forces equal to the weight of the motor and trans pushing it forward and sideways.
  27. hemihotrod66
    hemihotrod66
    The last biscuit type I bought was from NAPA and the have held up well....
    millersgarage likes this.
  28. millersgarage
    millersgarage
    I got mine at NAPA
    hemihotrod66 likes this.
  29. midnightrider78
    midnightrider78
    Got my Ch***is Engineering mounts the other day and installed them last night. I had to enlarge the hole in the lower portion of the steel mounts just slightly for the fancy shouldered washer. But, that is going to be so much better.
    Thanks for the recommendation guys!
    gimpyshotrods and Johnny Gee like this.
