Technical motor mounts 1937 Ford
Discussion in 'Traditional Hot Rods' started by 3wmike, Dec 9, 2021.
  1. 3wmike
    3wmike
    Recently bought this 1937 Ford frame, but I can´t recognize the motor mounts, are they original or is it something someone mounted later on
  2. 3wmike
    3wmike
    Sorry, I´m not able to send a picture
  3. sloppy jalopies
    sloppy jalopies
    are they riveted on, probably stock... bolted or welded ?
  4. Marty Strode
    Marty Strode
    This what a 37-40 should look like, with the exception of the CE bolt in mounts. IMG_2880.JPG
  5. 3wmike
    3wmike
    They are both riveted and "welded" on the top of the crossmember and they are moving the engine mounts both rearward and narrower
  6. alchemy
    alchemy
    Could be the weird V8-60 mount extensions.
    Dan Hay likes this.
  7. 3wmike
    3wmike
  8. Dan Hay
    Dan Hay
    From the pic you posted they are V860 mounts
    X38 likes this.
  9. Flathead Freddie
    Flathead Freddie
    Since sending a picture is not an option here what I do when I buy parts ' Sight Unseen ' or ' Unknown ' is to Google search so in your case I would Google - ' images of factory stock original 1937 frame ch***is ' and many images do come up and some of these are from HAMB and also factory manuals . I do this on a home computer as it's clearer to zoom in on the part of the frame I need to restore . Hope you can do this I just did this to identify an unknown frame in Great Lakes area and I'm in California and was able to identify the frame as an original 28 Chevy national frame . You can ask a car club member in your area if you can take a peek at their original vehicle also they are a great source for original builds
