Hot Rods Motorcraft Distributor Lubricant???
Discussion in 'The Hokey Ass Message Board' started by FityFive, Nov 28, 2023.
  1. FityFive
    FityFive
    I am working on recurving a Ford Motorcraft distributor. While I am working on it I thought it would be a good idea to lube the distributor shaft and under the advance weights. Does anyone know what lubricant I should use? Any recommendations or suggestions would be much appreciated.
  2. jaracer
    jaracer
    The old Ford point type distributor used motor oil. The weights were lubed by a wick under the rotor. You were supposed to put a drop of oil on it when you did a tune-up.
    deathrowdave likes this.
  3. deathrowdave
    deathrowdave
    from NKy
    Older distributors had and external oil tube with a flip cap , later went as Jaracer stated , lube under the rotor , then latest no lube . Which ever you had a few drops of engine oil a couple times a year and it will out last us .
  4. Marty Strode
    Marty Strode
    Some of the old tune up sets came with the small capsule of lube to lube the rubbing block on the points.
    ClayMart likes this.
  5. dalesnyder
    dalesnyder
    I’ve been using a synthetic multipurpose grease called ‘superlube’ it’s clear and available at Wally World,. I started using it on rifles and now use it any place I need too..
  6. jaracer
    jaracer
    When I was in tech school, our Carb and Ignition instructor told us to buy a tube of Delco distributor cam lube for the point rubbing block. He said a tube would last you a lifetime. I still have about 95% of that tube left.
  7. TA DAD
    TA DAD
    from NC
    I would not put any oil based lube under the weights, all it will do is attract dirt. I use some Teflon spray that dries and dirt does not stick to it.
