Motul motor oil
Discussion in 'The Hokey Ass Message Board' started by bagel56, Feb 23, 2012.
  1. bagel56
    bagel56
    from So. Cal.
    I was recommended by the builder of the car, a 38 Ford truck coupe, that he rocommends Motul motor oil, otherwise, I would screw up the heads on the flathead. What kind of Motul would you use?
  2. SpecialtyCars
    SpecialtyCars
    Motul has some great oils designed for older engines....both synthetic, conventional, or a blend. What type does the engine builder recommend?
    PM me if you need a source, as I'm a stocking Motul dealer.
  3. Motul does make some great oil, there is no question about that - it is used by many Top MOTORCYCLE Racing teams.
    But I would be VERY leery of any moron who said you could hurt the HEADS on a flat head because of oil. Flat Head heads have no moving parts. Seriously, I wouldn't listen to this guy!
  4. Willy301
    Willy301
    Yeah, oil won't hurt a flathead. But making sure whatever oil you run, has a zddp additive will protect a flat tappet camshaft. Not sure if Motul has it in it or not...but you can buy the oil with it in it, or just buy small quantities of the additive to put into what ever oil you choose to run.
  5. gimpyshotrods
    gimpyshotrods
    Hmm, imagine that, oil that messes up iron, or aluminum. That's a new one for me.
  6. SpecialtyCars
    SpecialtyCars
    Motul has a few formulations which are designed specifically for flat tappet engines. They contain high levels of zinc. They even have a specific formulation for hot rods and older sports cars.
  7. lostforawhile
    lostforawhile
    not trying to go off topic sorry, but what about older Japanese cars with flat tappets on the cam? I'm sure there are plenty of cars made here with the same situation, I have years and years in my project and I would hate to wipe out my new cam in a few miles
  8. B Blue
    B Blue
    I have no experience, but it is my understanding that once the cam (stock, not high performance) has been run in, the new gas engine stuff can be used. High performance slider cam, no way. Diesel rated oil is so common and will do the job, so why take a chance?
    Bill
  9. lostforawhile
    lostforawhile
    thanks, running a delta cam so I'm going to stick with the zinc oil, still pretty old stuff even if a bit off topic I have heard many good things about the Motul oil though
  10. SpecialtyCars
    SpecialtyCars
    The diesel oils are not bad, but they are not designed for gas engines. While they have a lot of zinc, that zinc tends to flash off at a different temperature than the zinc in gas engine oil. Also, a zinc level over 1000 ppm is for the most part unneeded, even for the most extreme flat tappet cams.
  11. bagel56
    bagel56
    from So. Cal.
    Sorry to confuse everyone here. It is the lifters that would be damaged by a non-zinc motor oil.
  12. :D And it only took 10 months to come back to the questions you asked? :eek:
  13. n847
    n847
    I spent some time talking to a Motul rep at the road races at Mid Ohio he had some very interesting stuff to stay about Zinc and ZDP oil. When I asked him if they had a high Zinc oil. He almost laughed as he pulled out his pamphlet then went into a long drawn out explaination of how they do have Zinc in their oils but its a very small piece of their formula, and how I should be looking for so much more than zinc and how I don't need Zinc even at start up or break in. I'm not saying his word was gospel but he had a lot of fancy lingo that sounded legit. I would recomend you contact a rep. I have his card somewhere but can't find it off the top of my head. I do know that it was pricey and I can't see it being vital for a flat head my self!
  14. bagel56
    bagel56
    from So. Cal.
    Yeah, but, it took 6 mos. to even get a response so I stopped looking at the thread as I thought my question was doomed from the start.
  15. I was going to say the same thing, what is there to screw up on a flat head? It has no moving parts.
    I didn't see it originally but I'll just about bet everyone thought it was a joke, it is pretty hard to screw up a flat head with a crow bar.
  16. Don's Hot Rods
    Don's Hot Rods
    from florida
    Haha, thanks guys. I needed that chuckle today ! :D
    Don
  17. no55mad
    no55mad
    Oil questions answered here: www.ZDDPlus.com They are Alliance Vendors here too - support the HAMB!
  18. Good point and the fella's builder was probably thinking cam shaft anyway.
    How silly would all this be if it turned out to have a roller cam. :D:D:D
  19. I'm just curious what a truck coupe looks like. :confused:
  20. CurbFeeler
    CurbFeeler
    QUOTE from that "Alliance Vendor -----"After 70+ years of trouble-free, metal-metal anti-wear protection, the E.P.A. is forcing ZDDP (Zinc Dialkyl Dithio Phosphate, containing both Zinc and Phosphorus) from domestic motor oil."
    That is NOT true. :mad:
    ZDDP levels were REDUCED not forced from domestic motor oil. They were reduced to pre-1970 levels.
    Eastwood Products were also claiming QUOTE-- "After 70+ years, the E.P.A. mandated that all domestic oil producers remove ZDDP (Zinc Dialkyl Dithio Phosphate, containing both Zinc and Phosphorus) from all conventional and synthetic motor oils."
    The editors of "Skinned Knuckles" magazine, where Eastwood Products was advertising, called out these un-true FEAR & SMEAR TACTICS and notified Eastwood ---- thus Eastwood dropped the EPA "mandated"crap from their advertising.
    Mouse-Milk and Snake Oil has always been composed of hyperbole, fear, and bullsheet. This time it's a gubernment cornspiracy freak-out designed to suck in the gullible to think they HAVE to buy the stuff ... "get it now before its all gone" or else.:rolleyes:
  21. In the aviation business we had a penetrating oil called "Mouse Milk". It worked great. It's still there; never been gone!
    I once had one of those little "Hyper Bole's". But, it scurried out into the street; and got run over. :D
    We had, I think, a Man Date Tree. Didn't give any Dates. :eek:
    The old man had a Gulleymoble; but the wheels fell off.:eek:
    Inadvertantly ran my '34 five Window, one night, without oil; only on the "sludge". The bearings rattled a bit. Put the oil in the 21 stud flathead. It ran fine. Is "sludge" O.K.? Maybe somebody has bottled it. What?
  22. no55mad
    no55mad
    After rounding off the cam lobes in 2 different engines, there was something obviously going on. Then the information started coming out about the reformulated modern oils which was causing this problem. Newer engines have roller lifters and can live w/o the higher levels of ZDDP. ZDDP causes problems in newer vehicles, like catalytic converters, which is why it was mandated to be reduced in modern oils. Comp Cams, Brad Penn, Amsoil and others are now offering oil with the higher levels of ZDDP for older engines. Is this effort of reformulated oil for older engines a 'snake oil' tactic?
  23. Give me 10! Aw hell, give me 20 bottles! *waves a mixture of gold, gravel and old tobacco enthusiastically*
  24. 40FordGuy
    40FordGuy
    Did I miss something here ? "Mess up the heads on a FLATHEAD" ??? The only fluid in those heads is engine coolant..........Oil doesn't get anywhere near them......
    4TTRUK
  25. bagel56
    bagel56
    from So. Cal.
    Thanx everyone for all the feedback, including the snake oil and pic of where to get it. It provides me with food for thought.
  26. bagel56
    bagel56
    from So. Cal.
    file:///Users/jamesvalente/Desktop/Your%20Car/2012%20Photo%20Image%20File.jpg
    Here is the car in question. Copy and paste it to your web browser.
