Hot Rods Mounting an alternator on a sbc with early heads and headers
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Apr 8, 2010.
  1. Roothawg
    Roothawg
    Just wondering what kinda contraption you have built for your alternator.
    I am having problems getting mine mounted. I am running an early 283 with a C4B intake that has the filler tube on front.
    No accessory bolt holes and headers. I bought a really nice piece today, Alan Grove bracket, but it interferes with the right hand outlet on the Mustang radiator I am using, so back to the Parts store it goes.
    I'd like it to stay somewhat simple since this car has a late 60's vibe.
    If I mount it on the opposite side it interferes with the oil fill tube. I may be able to shorten the tube. Anyhoo, how about some pics of your setup?
    Thanks
    Root
  2. Any room to mount it down below on the drivers side?
  3. I don't have a link, but Walden Speed has some pretty slick brackets for Alts/ Gens. Go on their site and search Jitney Jake (Jacobs). Might be what you're looking for?
  4. this was actually going to be my first suggestion/ question.
  5. If he has the room but doesn't wany one of those saddle type mounts that EVERYONE makes, it wouldn't be hard to use the same spacing and cut some swing arm that looks less modern.
  6. Speedway has those lower drivers side mounts, and others.
  7. Spity
    Spity
  8. you could make your own, this is stock stuff just modified a bit
    [​IMG][​IMG][​IMG]
  9. Roothawg
    Roothawg
    The Walden setup looks pretty sweet.
    I just don't want one of those modern looking spread out setups.
    I'll see if I can get some better pics of the motor tomorrow.
  10. gimpyshotrods
    gimpyshotrods
  11. Special Ed
    Special Ed
  12. river1
    river1
  13. DualQuad55
    DualQuad55
    from NH
    What's wrong with the old-fashion header brackets? They mount like the old rams-horn manifolds did. Cheap and available in damn near every speed shop or parts store selling 'performance' items.
  14. Captain Freedom
    Captain Freedom
    from Upstate SC
    Be brave, mount it under the car and driven by the driveshaft :)
  15. Roothawg
    Roothawg
    I have seen a lot of those "Chinese" brackets broken. I'm thinking they used old melted down Yugos to make em.
  16. hhatton
    hhatton
    check out socal speed shop. they have one that mounts it on the pass side . using there design i copied it and made mine. I'm running a 350 with a short water pump and a mustang radiator.the alter. mounts above the manifold , which has a boss for the early oil tube and clears it. if you want i can post a pic. its a 32 ford and if i want i can run a full hood and sides , it'll clear no problem.
  17. Roothawg
    Roothawg
  18. The coupe is looking rad. Will it be at MoKan in August?
    -mikethegreek-
  19. Roothawg
    Roothawg
    Man I hope so. If it's not done in a couple of weeks I'm gonna hang myself....:D
  20. poboyross
    poboyross
    from West TN
    I ordered one from Alan Grove that put it over the pass. side valve cover, like so:
    Granted, it's in my 50 Chevy..but if you order it online, you can get a bracket to put anything anywhere!
  21. Greezy
    Greezy
    Cars looking good Root. Makes me miss mine a bit. Ill rephrase that to I wish I would have finished it.
  22. Roothawg
    Roothawg
    Thanks. Mines a beater. Your car was nice.
  23. Ricks57
    Ricks57
    from San Diego
    Hi,
    I'll second Alan Grove, they provide a variety of mounts for every situation. Gives you some options.
    Rick
  24. oldpaint
    oldpaint
    I have an Alan Grove lower left on my 40 coupe. Good quality stuff! Check his site he makes almost every combination.
  25. Mr48chev
    It probably wouldn't cost all that much to have a radiator shop move the outlet over to the passenger side of the radiator and then you could run just about any standard low mount that is available to match your water pump and not have to have the Mickey Mouse lower hose setup. Two problems solved.
  26. deucemanab
    deucemanab
    I AM USING BILL'S HOT ROD COMPANY BRACKETS ON A 64 CSB,MOUNTS THE ALTENATOR HIGH ON DRIVERS SIDE. GREAT UNIT. 626-332-1915 OR WEB SITE
    WWW.BILL'SHOT ROD COMPANY.COM
  27. Joliet Jake
    Joliet Jake
    from Jax, FL
    I made my own bracket, I hated having it sticking outside the grill shell. I would've had to modify it if I had a breather tube in front.
