Technical Mounting Rear brake adjusters
Discussion in 'Traditional Hot Rods' started by FlatJan, Nov 2, 2023.
  1. FlatJan
    FlatJan
    Hi Folks
    don't know if anyone posted this before but i thought I'd share some hints how to mount those "gear to mount" lower adjusters.
    By hand it's not fun doing it and I've tried several times till i figured this out.
    First mount the asymmetric washer into shoe
    Next wiggle in special bolt
    now thats kinda easy without the connection plate in front of it
    the trick is to fix the shoe now by clamping it
    take out special bolt, shoe still clamped
    position connection plate and put special bolt back in
    put nut on special bolt on rearside of backing plate
    take off clamp
    now was that easy?
    make sure the special bolt fits easily but snug into asymmetric washer. wasn't the case on mine (repop and original washer with original bolt)
    you can do both bolts like that.
    don't know if this was needless but would have helped me
    282doorUK and pprather like this.
  2. 282doorUK
    282doorUK
    Thanks for that neat trick, very timely as I'll be wrestling with mine this morning.
  3. I just put the washers on the bolt first, then the plate and insert them both at the same time. While holding the bolts in place with one hand, start the nuts and hand tighten.
