Technical Mounting rear spring perches for model a
Discussion in 'Traditional Hot Rods' started by straycat60, May 7, 2023.
  1. straycat60
    straycat60
    I am getting ready to Weld Spring perch brackets on a newer rear to mount the Model A buggy Spring. I was wondering how to space those brackets do I just go approximately The width of the Spring or should I spread the Spring out some?? Many thanks
  2. '29 Gizmo
    '29 Gizmo
    from UK
    Stock model A spring fits a 49" perch centers. A model a spring needs to be spread alot.
    Tow Truck Tom likes this.
  3. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Sounds right to me. However I couldn't get under mine.
    I measured spring eye to eye at 46" and upper ( 2" ) hanger bolts 47" ( thru the trunk )
  4. Jmountainjr
    Jmountainjr
    You need to have an allowance for the shackles, so the distance is a bit longer than the uninstalled spring. The number that most often comes up is 49" - 49.5". When you install the spring either dis***emble the spring and install the main leaf, or have a purpose built spring spreader and be careful.
    dirt t and sidevalve8ba like this.
