Mounting side-bias ply tires
Discussion in 'The Hokey Ass Message Board' started by mink, Jun 14, 2013.
  1. mink
    mink
    from CT
    Which is the correct or preffered side to mount new bias ply tires on your rim? Dot code facing toward or away from car?
  2. 3wLarry
    3wLarry
    from Owasso, Ok
    only your hairdresser knows for sure...
    kidcampbell71 likes this.
  3. HOTRODPRIMER
    HOTRODPRIMER
    probably doesn't matter. HRP
  4. 1951Streamliner
    1951Streamliner
    from Reno, NV
    The mount them with the white facing out :)
  5. mink
    mink
    from CT
    lol, got it. Guys sent me the right inner tube with the wrong valve stem size, So i have some time to decide
  6. Bad Eye Bill
    Bad Eye Bill
    from NB Canada
    Dunno, don't think it would make any difference. Guy I used to work for claimed you had to put the DOT mark next to the valve to make balancing the tire easier, tried it there and randomly mounting the tire, didn't seem to make much difference.
  7. Mr48chev
    The DOT stamp always goes IN unless you don't like the sidewall on that side of the tire. It just gives a cleaner appearance when you have it mounted. That was one of the first things I learned when I started mounting tires in the 60's.
  8. silent rick
    silent rick
    i faced mine in also
  9. mustangmike6996
    mustangmike6996
    from the D
    i always put the DOT in but it depends on whether or not its a styled sidewall..
  10. jcmarz
    jcmarz
    from Chino, Ca
    I thought the dot went on the forehead
